Old 10-25-2002, 05:42 PM   #1
photoglg
photoglg's Avatar
Fender Welting
Has any one used the black rubber fender welting on a 67-72 stepside. I just don't remember seeing any trucks with it. I have the fenders off and have just had the bed and fenders painted and want something better than metal to metal.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 10-25-2002, 08:42 PM   #2
dbenamati
dbenamati's Avatar
I bought some of that a few years ago to use on my step side when I repainted. It looks nice but if I had to do it over, I don't know if I would use it again. The stuff was a bear to keep on while putting the fenders back on. I had to duck tape it fast while I fed the bolts through and it was tough getting it to strech around the curved parts. I have seen a few trucks without and look nice. It is only a thin strip of vinyl around a plastic hose the size of a pencil. I don't think it will matter metal to metal as long as it is painted surface to painted surface.
Dave Benamati
Hughesville, PA USA
dbenamati is offline   Reply With Quote
Old 10-26-2002, 07:55 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I just used some on my truck after painting it and I highly recommend it! It eliminates the metal to metal contact that will cause rust but more importantly, it keeps water, mud and whatever else from spraying up through. It gives the truck a nice "finished" look too.
The way I installed mine was to loosely install the fender with 2 bolts up in the middle. (out of the way) I then started at one end (the back end is where I chose to start) and slipped in the fender welting and punched the holes through with an ice pic as I went. Install each bolt loosely as you go to and it will hold it in place. Once all is in, tighten down all bolts.
It wasn't hard to do but you do need some patience so as to not rush the job.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Thread Tools
Display Modes
