Old 03-04-2008, 08:20 AM   #1
rawraw67
rawraw67's Avatar
69-72 under Dash harness
How can I tell the difference on the two under dash harness for 69-72 ?
rawraw67 is offline   Reply With Quote
Old 03-04-2008, 09:17 AM   #2
stope4
Re: 69-72 under Dash harness
I think the only difference is ac or non-ac. Does your truck have ac? Does it work?
stope4 is offline   Reply With Quote
Old 03-04-2008, 09:37 AM   #3
rawraw67
rawraw67's Avatar
my Truck does not have ac.There is a difference in the two harness,there is a harness for warning lights and a harness for gauges I have warning lights now and my harness is ok,but I want to put the factory gauges and the right harness.so I want to know what to look for on a gauges harness so I can identity it is the right one.
Old 03-04-2008, 09:03 PM   #4
Luvlegs
Luvlegs's Avatar
I belive the only differences are either unused connections AND the different locations for the wires on the cluster plug. Things like the oil pressure sending unit - if you go to guages, it's not used as it's hard plumbed in.
Check the FAQs for the diagrams (latest one I saw also has the guage plug setup label at the top of it). They are for a V8 but very close to the 6 cylinder setup. I just redid my entire harness and posted some info on here in the past 3 weeks or so.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Thread Tools
Display Modes
