Old 03-04-2008, 10:44 AM   #1
JQ-72
JQ-72's Avatar
Factory restoration info ?
Well, I've got nearly everything to start restoration on my 72 Super. Does anyone know of a website or location to find information about factory paint marks - like on steering sectors, alternators, master cylinder? There's probably not any "truck" links out there, but there's gotta be something out there for Camaro, Corvette. Thanks for any help.
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 03-04-2008, 10:59 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Factory restoration info ?
Your at the source,
I would start with one item and ask for pics of exactly what your needing then go from there
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-04-2008, 07:17 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
You can get some kind of information packet from GM but I'm not sure what it includes or how you go about getting it. Maybe one of the guys that knows will post up.....
LockDoc
Leon
Old 03-04-2008, 07:28 PM   #4
JQ-72
JQ-72's Avatar
Yeah, I got one of those restoration packs - just B&W stuff. I'm looking for some restoration photos - you see these high $$ Chevelles, Camaros, etc. that look better than showroom new and they have all the correct markings. Also need to know what frame and suspension parts are black and what are cast iron gray.
JQ
Old 03-05-2008, 06:46 AM   #5
sameyrasmea72
sameyrasmea72's Avatar
Are you talking about these type of markings?
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-05-2008, 06:50 AM   #6
sameyrasmea72
some of my cast stuff.
72 Cheyenne Super
Old 03-05-2008, 07:14 AM   #7
dazza
dazza's Avatar
These might help... http://67-72chevytrucks.com/vboard/s...t=yellow+black
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 03-05-2008, 07:47 AM   #8
71 super
71 super's Avatar
Sammy has some photos there to go by. My 71 has 118 under the driver's side bucket on the floor, and the A50 on the core support as well as paint code under the M/C and the wheel base info on the firewall as well as VIN #. The wheel base 10734 is on the pass frame rail, and the rear most crossmember. The hood springs had a yellow dot on the end of each spring and a spot of paint on the steering sector at the top of the inspection plate? The springs (Front) have a white band of paint close to the lowest spring in the cup. There is a dot of paint on the top of the M/C cover and a tag around the bails of the M/C as well as one around the throttle cable. Do not know if the there were any codes on the alt like on the camaros but there prob. were. If you are looking for 100 pts. I suggest running down tower clamps, white striped vac. hose, correctly bent PCV hose, and the correct ribbed heater hoses and vac. lines as well as washer hoses. Most of this stuff is available but not from truck places- try NPD and Rick's first generation in Tucker GA. They have most of the detail stuff like this as well as stamps for booster and Alt. If you have any questions or need pictures of this stuff shoot me a PM and I will try to help you out. Also start searching for an original truck with the evap. canister in place- they usually have the original evep hose still in place - they have GM numbers etc. that are not reproduced anywhere and really make the engine look right.
71 super is offline   Reply With Quote
Old 03-06-2008, 01:16 PM   #9
JQ-72
JQ-72's Avatar
Thanks for these pics - that's a start. I went to a Super Chevy event a few years ago and saw a 69 Camaro that was pristine. It had correct markings on master cylinder, steering box, radiator support, and lots more stuff. I should have taken lots of pics! Just checking to see if anyone knew of a link that showed location and color of all marks GM used or some restoration photos showing this stuff.
JQ
Thread Tools
Display Modes
