Old 03-05-2008, 07:52 PM   #1
scejmer
scejmer's Avatar
Question transfere case
i was thinking of rebuilding the case, made a groul in low lock last summer, but did have a broken trans mount, has anyone done one these, it has some seals leaking anyways, so i thought it might be wise do check the whole thing out before summer gets here, any input or posible manuals on rebuild would be appreciated, thanks scott
scejmer is offline   Reply With Quote
Old 03-05-2008, 09:49 PM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: transfere case
Replacing the seals is no big deal. Not sure about replacing internal parts.... I guess it depends on the growl. Every 4x4 vehicle I've owned makes a sigificant noise when in low lock. Kind of a whining/growling noise. If your broken tranny mount put the driveshafts in a bind on the transfercase, it will make it growl. I've done that one.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 03-06-2008, 07:54 AM   #3
Musclerodz
Re: transfere case
I have done several. Just make sure to pay attention to the order of disassembly. Not all that complicated.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 03-06-2008, 10:22 AM   #4
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: transfere case
Does anyone have a cut sheet of the transfer case. I am in the process of cleaning mine to paint and would like to disassemble so I can paint the cast area. I was a little weary of doing this but if it is easy to do I will attempt it with some documentation.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 03-06-2008, 10:33 PM   #5
Musclerodz
Re: transfere case
http://www.offroaders.com/tech/Diagrams/np205.htm
Mike Redpath
Old 03-06-2008, 10:41 PM   #6
scejmer
scejmer's Avatar
Re: transfere case
thanks for all the help so far, and always is greatly appriciated.
Old 03-07-2008, 03:10 AM   #7
JayDubBlazer
go cyclones
Re: transfere case
Perfect, thanks
Wes
PROJECT OLE GREEN
2017 Silverado LT
Thread Tools
Display Modes
