Old 03-12-2008, 07:23 AM   #1
oldspowered67C10
Frame repair and 67 p/s conversion
Hey everyone, so I have the body off my truck so I decided that Id fix my frame and correctly install a 69-later sytle power steering box. When I first got the truck someone had installed a car power steering box. Since on a car the box mounts to the inside of the frame rail they welded a piece of 6"x6" square tube to the frame rail and installed the box inside the tube. I guess they wanted a quicker ratio box. Reguardless of why they did it they beat the hell out of the frame rail to make the tube sit flush.
After looking at the damage I decided it would be best to replace the entire side of the frame rail in that section. Also my frame doesnt have the "bump in" to clear the power steering box so I figured I could intergrate the "bump in" into the new piece. Heres as far as I got before running out of welding wire.
oldspowered67C10 is offline   Reply With Quote
Old 03-12-2008, 07:30 AM   #2
Shane
Shane's Avatar
Re: Frame repair and 67 p/s conversion
looks good!
Shane is offline   Reply With Quote
Old 03-12-2008, 08:44 AM   #3
shifty
Questionable
shifty's Avatar
looks really good. you gonna fish plate the inside for strength?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-12-2008, 08:53 AM   #4
Shane
Shane's Avatar
what the hell is a "fish plate" ???
Old 03-12-2008, 08:58 AM   #5
shifty
Questionable
shifty's Avatar
(Thanks Glock35ipsc, thanks Google site search! )
Old 03-12-2008, 08:59 AM   #6
shifty
Questionable
shifty's Avatar
I guess the term isn't used as much as I thought. I didn't get a ton of hits here at the site, but ... this is what pulled up, so you know I'm not a nutbag (I just read too much): http://www.google.com/search?sourcei...vytrucks%2ecom
Old 03-12-2008, 09:00 AM   #7
Shane
Shane's Avatar
i guess, but i've never seen a "fish plate" on the inside of an original frame ... can't really see a purpose for it ...
Old 03-12-2008, 09:07 AM   #8
shifty
Questionable
shifty's Avatar
I read you're supposed to use them any time you cut into a frame and weld a patch. So, in this case, from all the fab crap I've been reading, he would want to add at least a diamond or oval shaped fish plate on the inside of the framerail at each of the vertical seams shown in the picture.
I am not a fab guy, I'm just interested, so I can't say (that's why I asked!)
Old 03-12-2008, 10:16 AM   #9
oldspowered67C10
I was thinking that rather than a fish plate welded parallel Id make some gussets that weld to the plate perpindicular and also weld to the existing frame top and bottom, well see how it goes.
Old 03-17-2008, 05:52 AM   #10
oldspowered67C10
Finished up today, got it all welded and the welds dressed on the outside. Ended up making 2 gusset plates for rienforcement and it looks like itll hold.
Old 03-18-2008, 05:57 AM   #11
shifty
Questionable
shifty's Avatar
looks really good!
Thread Tools
Display Modes
