Old 05-06-2002, 11:16 AM   #1
dubie
dubie's Avatar
Post What rear end is my 72 likely to have??
It is a factory 250 inline, 3 speed manual setup. Just curious as to what type of rear end came in truck with this powertrain set up. Thanks
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-06-2002, 11:30 AM   #2
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Post
72 C10 6 -cylinder ,3 speed manual
stock 3.73 ,Optional 3.07 or 4.11
72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings
tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40.
Torrance Calif.
" If I knew I was going to live this long I would have taken better care of myself "
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 05-06-2002, 12:29 PM   #3
gmc-rob
Post
How do you know what rear end a truck has? I just bought a 1971 GMC 2500 serria grande camper special with heavy coils springs and a th400. The rear end looks huge and the guy said it has a posi?? Thank you , ROB
gmc-rob is offline   Reply With Quote
Old 05-06-2002, 12:48 PM   #4
bigvinnie
bigvinnie's Avatar
Post
best way to verify posi is to get both rear tires off the ground, then spin one of the tires... if the other tire spins the same direction you have a posi.
While you're off the ground, make a chalk mark on one of the rear tires and spin it thru one complete revolution while watching how many times the driveshaft turns... if it's just a little more than 3 revs, it's a 3.07... a little less than 4, it's a 3.73... a little more than 4, it's a 4.11... good luck.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-06-2002, 01:11 PM   #5
ViperRed67
Post
I had a 71 3/4 and it had a Dana 60 in the rear. This can be checked by looking at the casting mark on the lower right side next to the diff cover. It should just have a 60 there. Could also be a Eaton type, these have a drop out center section from the front. In half tons, I have seen both the 12 bolt and dana 44 rears.
ViperRed67 is offline   Reply With Quote
Old 05-06-2002, 01:59 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
Post
coil is most likely eaton axle in a 3/4 ton
look for axle No Spin G86 on glovebox door, if its there thne its ane eaton 5200lbs drop out center axle, be careful with axle keep eye closely on fluid level they are known for puking out fluid and chewing al bearings and no parts are available for them anymore, last used in 1972 since 1947
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, driver, was free
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-06-2002, 02:14 PM   #7
ViperRed67
Post
For what its worth "Randys ring and pinion" is now making all new ring gear sets for the eaton axle. Even down to 3:73 ratio
Old 05-06-2002, 02:17 PM   #8
Fast68Chevy
Post
i meant stock replacement type parts, whats the addy to the page that lists the eaton 10 bolt gears ?
Randy- Lincoln, IL
Thread Tools
Display Modes
