Old 03-15-2008, 05:41 AM   #1
Painter D
Painter D's Avatar
airline routing ( quick question)
when you bag the front of these trucks , where are you guys running the airline? what i mean is , are you drilling a hole in the top or the back or wherever in the crossmember. (factory crossmember) any help would be great , pics would be even better.
Painter D is offline   Reply With Quote
Old 03-15-2008, 07:37 AM   #2
shifty
Questionable
shifty's Avatar
Re: airline routing ( quick question)
I was interested in this too. I looked around and found three different installs of people who were running their lines through a hole drilled in the crossmember.
I reaelly want to see some feedback on this topic too, I'm definitely interested!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-15-2008, 07:42 AM   #3
jlaird
jlaird's Avatar
I've seen it where a hole is drilled through the side of the crossmember OR below the upper a arm. Simple grommet is used and/or cover your plastic line with rubber fuel line as an added safety measure.
The other option is to install a bulkhead somewhere on the crossmember. So basically you would run your line from the bag to the bulkhead, then from the bulkhead to your valves.
bulkhead:
jlaird is offline   Reply With Quote
Old 03-15-2008, 07:47 AM   #4
Shane
Shane's Avatar
i drilled a hole in the rear of the cross member and inserted a grommet to prevent the line from chaffing on the edge of the hole.
several guys here have used bulkhead type fittings with good results, but remember that more mechanical connections mean more chances for a leak to develop
EDIT: was typing while jlaird was posting
Shane is offline   Reply With Quote
Old 03-15-2008, 07:51 AM   #5
jlaird
jlaird's Avatar
great minds
Old 03-15-2008, 09:10 AM   #6
bedsled71
bedsled71's Avatar
mine is through the top
bedsled71 is offline   Reply With Quote
Old 03-15-2008, 11:57 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
I'm in the "fewer fittings=fewer leaks" camp:
Frizzle Fry is offline   Reply With Quote
Old 03-15-2008, 05:59 PM   #8
jlaird
jlaird's Avatar
Frizzle, are those self tapping screws in that last pic? Does the screw go all the way through the frame and stick out the other side? I'm trying to figure out what the cleanest way is to fasten line clamps.
Old 03-15-2008, 10:29 PM   #9
Frizzle Fry
Yes. You can see that they really detract from my otherwise show-quality frame...
Old 03-15-2008, 11:53 PM   #10
TimE
Hey Y'all!!
TimE's Avatar
Good one, Frizzle. The bad thing is, YOUR frame IS show quality compared to mine. One day...
TimE is offline   Reply With Quote
Old 03-16-2008, 06:35 AM   #11
Painter D
Painter D's Avatar
Well i ended up drilling a hole in the back of the crossmember like the one in the pic. I'll try to post pics of progress later. Also, I'll be running 2800 lbs. bags out back , this was recommended by a very experienced fabricator that i have known for 10 years , and who has bagged probably around 60 - 70 vehicles. I thought thes bags might be a little big but he said it would ride better. Has anyone else run these big bags out back on these trucks? I had 2800lbs. bags on the back of my bodydropped s-10 years ago and it was fine, but i was curious how they rode on these trucks.
Old 03-16-2008, 07:43 AM   #12
bdydrp97s10
bdydrp97s10's Avatar
ive heard to use 2800 in the back
bdydrp97s10 is offline   Reply With Quote
Old 03-16-2008, 06:03 PM   #13
jlaird
jlaird's Avatar
Yes, that is what I am doing only slams RS8's (now renamed RE8)
concerning the line brackets, what are other options to affix line to the frame (besides zip ties) I'm not saying I don't like the self tapping screws, just want to know all my options before I go start drilling holes in my frame.
Old 03-17-2008, 04:35 AM   #14
Shane
Shane's Avatar
I used these from Kugel Komponents ... 3/8" stainless with stainless screws .. you will need to drill & tap, but not a big deal and they look GREAT.
Old 03-17-2008, 05:35 AM   #15
Painter D
Painter D's Avatar
Well I got all of the front end done today, its ready to be reassembled. But I have to get all of my control arms back from the chrome shop first, I'll post some pics later on.
Old 03-17-2008, 05:37 AM   #16
jlaird
jlaird's Avatar
Shane,
Those are really nice. Thanks for the link. Have a question for ya. Did you use those on plastic air line? The first thing that came to my mind is the metal clamps rubbing a hole in the plastic. Usually those clamps that are lined in rubber are used for plastic line. Maybe I'm worrying too much?? What do you think?
Old 03-17-2008, 05:41 AM   #17
Shane
Shane's Avatar
Yes sir, 3/8" DOT plastic tubing. Nothing to rub as the tubing is held stationary and can not move.
Old 03-20-2008, 10:03 PM   #18
Wasted Income
Boosted Member
Wasted Income's Avatar
Mine is thru the crossmember like frizzle fry's.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-21-2008, 05:31 AM   #19
Painter D
Painter D's Avatar
I ended up doing mine similar to Frizzle Frys also.
Old 03-22-2008, 07:38 PM   #20
Frizzle Fry
Those are nice Shane. I think I'll go to those if/when I replace my lines with copper.
Thread Tools
Display Modes
