Old 03-15-2008, 07:47 AM   #1
shifty
Questionable
shifty's Avatar
Stupid decision?
Ok, looking for some feedback and advice.
I decided (based on rust I found on old crossmember) to go with the '77 crossmember. Here are my thoughts:
Only two out of four holes on the side of the framerail line up on my '68 for bolting up the crossmember; one needs "wallering", the other needs a fresh hole. Rather than make an "L" shaped hole wallering the one out, I thought: Why not weld up the two misaligned holes, and jus redrill them? I'll never go back to a '68 crossmember. Sound crazy, considering I'm having it powdercoated and never want to touch it again?
Also, am I stupid to weld up the holes from other things, like the old 3spd crossmember I'll never use again, etc?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-15-2008, 07:53 AM   #2
jlaird
jlaird's Avatar
Re: Stupid decision?
weld away.
jlaird is offline   Reply With Quote
Old 03-15-2008, 07:57 AM   #3
shifty
Questionable
shifty's Avatar
I have a magnetic copper backing plate. Is it hard to patch a hole on a vertical wall cleanly?
I think I'm going to shave the excess holes in my crossmember also (for the diff't engine mounts). Not sure I'll need those either.
Old 03-15-2008, 08:01 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Sounds like a lot of extra work to me, but it should make for a nice piece once it's in powder. Just make sure you mock everything up so you're not welding up any holes you might need later...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-15-2008, 08:03 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
The weld will be easy, especially on a bare frame you can flip over. Grinding them smooth inside the "C" will be a pain...
-Chris
Old 03-15-2008, 08:10 AM   #6
Shane
Shane's Avatar
I'm with Gringo on this one ... sounds like a LOT of work for minimum return.
Shane is offline   Reply With Quote
Old 03-15-2008, 08:12 AM   #7
shifty
Questionable
shifty's Avatar
Minimum return, but here's my beef: The two holes I'd be welding for the engine mounts are less than 1mm-2mm away from the new holes I need for my mounts to work. One of the two holes for the crossmember to bolt up proper is less than 1mm-2mm from the new hole. So, if I'm welding up a lot of holes already to patch up my previous installation/hackery, and welding up other holes...is it really a lot of xtra work with minimum return?
Old 03-15-2008, 09:15 AM   #8
SanitysBane
Do it! I wish I took the time on my frame and welded up all the extra holes instead of having something that looks like swiss cheese.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 03-15-2008, 09:47 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
You will be glad you took the extra time to clean it up.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-15-2008, 09:51 AM   #10
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
These trucks are alot of work to begin with when doing a frame up. I say go for it. It's the little things that bring out the detail.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-15-2008, 10:09 AM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
yeah, I would do it on my truck for sure... in fact I did weld up a lot of holes and its not even noticeable.... and it the kind of thing only you can appreciate.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-15-2008, 11:48 AM   #12
Frizzle Fry
Frizzle Fry's Avatar
Just be warned that drilling through a welded-up hole can be a serious PITA. So if a new hole overlaps where an old one was welded up be prepared to invest in some quality bits. Otherwise I say clean-er-up!
Frizzle Fry is offline   Reply With Quote
Old 03-15-2008, 01:09 PM   #13
Bishops Trucks
KEEP ON TRUCKIN'
Good bits and keep them lubed while drilling and all should go smooth.
JIM
Old 03-15-2008, 04:42 PM   #14
smashingchuck
Tap magic, and keep the bit sharp.
78 Build Thread
4Runner Build
Old 03-15-2008, 07:16 PM   #15
LONGHAIR
Magnets around the weld will cause problems. A magnet will pull the molten weld pool to it. If you use one for postioning, try to keep it as far away from the actual weld as you can. Tack a few places and remove the magnet.
I am not a fan of the copper backing either, especially in something as thick as a frame rail. You should be able to weld the edges of the hole, effectively shrinking it, until you can "bridge" it closed. If it is too big for that, it needs a patch anyway.
Like this......
LONGHAIR is offline   Reply With Quote
Old 03-16-2008, 12:03 AM   #16
shifty
Questionable
shifty's Avatar
The chunk of copper I have is this one: http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
It's 4"x2", roughly, and the magnets are on the farthest corners and are tiny (but strong enough to hold it to metal.
The comment about drilling through a welded spot actually concerns me, because I'll actually need to be doing just that. Is it really that bad? I have some decent quality drill bits to work with.
Old 03-16-2008, 07:53 AM   #17
jjk3
It's just a check engine lamp.
jjk3's Avatar
Just keep the drill bit lubricated, and don't over speed the bit. This is where patience is a good thing to have.
I agree with the others, it's worth the extra time to fill in the holes. Good luck.
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
Thread Tools
Display Modes
