Old 03-18-2008, 09:26 AM   #1
68c10owner
68c10owner's Avatar
73 up rearend for my 62?
i`m buying a 73 up crossmember kit and the guy has the rearend from the truck as well. I know I have to buy the new mounting brackets butwill it be a problem that they are about a 1" wider? Really thats only about 1/2" per side. The guy wants $325 for everything. Is that a decent price?
Anthony
68c10owner is offline   Reply With Quote
Old 03-18-2008, 09:36 AM   #2
joehalford01
joehalford01's Avatar
Re: 73 up rearend for my 62?
i paid $100 for an entire 77 parts truck minus the motor and tranny.
joehalford01 is offline   Reply With Quote
Old 03-18-2008, 09:46 AM   #3
68c10owner
68c10owner's Avatar
Man that would be nice. I don`t have the room for a complete truck where I`m at. The stuff is really clean. Looks like it will bolt up and go.
Anthony
Old 03-18-2008, 09:53 AM   #4
poorboy
poorboy's Avatar
The rear end will fit. I believe it's the same width as a 72 and they work fine. Have you thought about getting 6 lug rotrs and leaving the rearend in the truck.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
Old 03-18-2008, 09:59 AM   #5
poorboy
poorboy's Avatar
Here's a link to some rotors. $129 for the pair.
Old 03-18-2008, 10:03 AM   #6
68c10owner
68c10owner's Avatar
I thought about it but I want to get rid of the torsion bars and go with coils. i know you can lower the torsion bars with some adjustments but I would just rather convert it. I don`t think the stock rearend would hold up to the engine I`m planning to build for it.
don`t see a link.
Anthony
Old 03-18-2008, 10:03 AM   #7
poorboy
poorboy's Avatar
Also you dont need to swap the whole crossmember. All you need are the upper and lower arms and steering.
Old 03-18-2008, 10:06 AM   #8
poorboy
poorboy's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=263983
Old 03-18-2008, 10:08 AM   #9
68c10owner
68c10owner's Avatar
Thanks. I didn`t know that. I thought you had to swap the entire thing. My buddy did it years ago to his 60 so I thought to get rid of the torsion bar set up you needed to swap everything. The guy cut the frame off behind the crossmember so I can just pull off what I need. He wants $200 for the front stuff with the steering box and $125 for the rearend. They are out of a 73.
Anthony
Old 03-18-2008, 10:16 AM   #10
poorboy
poorboy's Avatar
I totally forgot that 62's still had bars up front. I think you'll need to swap out the crossmember after all to get the spring pockets.
Old 03-18-2008, 10:21 AM   #11
68c10owner
68c10owner's Avatar
Yeah i was just reading the disc brake swap l you linked to and most people said for 60-62 trucks to just swap the whole thing so you don`t have to play around with ball joints and tie rods. I`ll just swap the whole thing.
Anthony
Old 03-18-2008, 03:53 PM   #12
Stepside65
Still Truckless!
Stepside65's Avatar
what kinda numbers are you expecting out of the motor you're plannin to put in? you'd be suprized what that rear axle can handle. That extra half inch can be compensated for with different backspacing.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 03-18-2008, 06:37 PM   #13
68c10owner
68c10owner's Avatar
I`m planning to build a sbc to about 400-450hp. I would just rather have a more common rearend for ease of parts as well. Plus I get the 5 lug conversion.
Anthony
Thread Tools
Display Modes
