03-20-2008, 08:10 PM | #1 |
Lift Kit troubles
I got a rough county EZ-ride lift. I ordered a 2" and they sent a 4", but that is ok! I have the front put on, but the back springs are giving me trouble!
The old shackle bolts will not budge! I cut the fronts ones out by cutting the springs off and then cutting the wrapped bushing out---lots of fire and smoke!! The back hanger is the problem. I can't cut the shackle up because I have to reuse it. Any suggestions!!!!!! I figure I will probably have to melt the rubber bushing out----anyone have a better idea??????? Thanks john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
03-20-2008, 09:03 PM | #2 |
Re: Lift Kit troubles
drill a bunch of holes in the bushing, honey comb it
Pry and peal it out
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
03-20-2008, 09:14 PM | #3 |
Post Whore
I took the approach Burt mentions - it is a major pain! I did notice that www.offroaddesign.com does sell replacent rear shackles now, I don't know if they are the same dimensions as the original though.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-20-2008, 09:20 PM | #4 |
could you sawsall the bolts?
"Beer is proof that God loves us and wants us to be happy" Ben Franklin 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
03-20-2008, 10:21 PM | #5 |
I had the same problem and used the fire and smoke method!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
03-21-2008, 09:40 PM | #6 |
I use pb blaster, 3/4 drive breaker bar and a big hammer. Soak it the night before and during the job.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
03-22-2008, 04:00 AM | #7 |
wow you orderd a 2 inch lift and got rear springs too? i figured you would have gotten blocks for the rear, was it expensive?
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
03-22-2008, 04:49 AM | #8 |
Well, Whoop-dee-do!
Just went thru this last fall on mine. don't have a torch or sawzall, so I used a 4-1/2" angle grinder and cutoff wheels to hack them up. I hacked the shackles too. They were about $20 or so a piece at the spring shop.
So much fun
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
03-22-2008, 05:18 AM | #9 |
I think I had to torch them out, did damage the shackle a bit but it worked...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-22-2008, 05:30 AM | #10 | ||
Thanks for the replies---- The price was about 800 with shocks. I used the grinder and cut off wheels--it worked!!!!! I hate inhaling smoke from the rubber bushings! I stayed up till 1 am, but I got it all put back together. The weird thing is that the lift raised the front by 4 inches and the back by 3 inches. Plus they sent me the long shocks for a 4 inch lift ( 30" verses 26"). I just put the monroe gas shocks back on ( pretty new). I am tempted to take one leaf out of the fronts ( 3 leaves ). Would it be better to build a block and raise the back? Here are some Before and After pics. Thanks john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 03-22-2008 at 05:39 AM. |
03-22-2008, 05:59 AM | #11 |
wow thats a nice looking truck you have, i hada 69 about that color, glad you got it all back toghter, does the ez ride springs work good? how does the ride compare to regular lift springs?
03-22-2008, 06:20 AM | #12 |
Thanks,
The rear rides pretty good, but the front is very,very stiff. I think I should take out one of the leaves. john ps---I saw pics of your red SWB 4x4----very nice truck!!!!!!!!!!!!!!!!
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 03-22-2008 at 07:26 AM. |
03-22-2008, 06:20 AM | #13 |
Well, Whoop-dee-do!
The front height looks PERFECT IMO
Maybe add a 1-1/2" or 2" block to the rear, OR, do it the different hard way as I did. I put rear hangers on from an '84 K30 SRW. They are longer. The mounting pattern is different, but since I used 56" rear springs, I was going to be drilling anyway.
03-22-2008, 07:09 AM | #14 |
Jeff,
Did you put the 56" springs on a short bed? I am wondering if the longer leaves would help center up the back wheels in the wheelwell. It seems to me that the back axle sets too far forward. Thanks, john
03-22-2008, 07:23 AM | #15 |
You could put a 1" zero rate from ORD and move the axle back at the same time.
Bruiser |
03-22-2008, 05:54 PM | #16 |
Post Whore
Gotta agree the front height looks real good. I'd definitely go with the 1" Zero Rate block that Bruiser recommended. Get that rear axle back a little and get your height evened out.
03-23-2008, 01:20 AM | #17 | |
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
03-23-2008, 03:28 AM | #18 |
msgross,
How did you know I was a lazy a__????????? Seriously, thanks for the link. That is just what I need---sure am glad I didn't chop the bottom off the U-bolts yet!!!! Thanks for all the help. john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 03-23-2008 at 03:31 AM. |
03-23-2008, 06:30 AM | #19 | |
Well, Whoop-dee-do!
I'm running 2" longer leafs on the front. The centerbolt is centered as the OE springs were- so I made up the 1" offset by drilling new holes in the axles spring mount pads 1" further back. I've done it many times- I call it zero inch zero rate
03-26-2008, 12:49 AM | #20 | |
good luck
03-27-2008, 07:01 PM | #21 |
Hey JRDV what did you do with the wheels in the first pic. I have been lookin for a couple since...um the incident. If you looking to get rid of em email me at "elwayno1@comcast.net"
04-05-2008, 08:19 AM | #22 |
I ordered the ORD Zero Rate blocks. Of course I only measured once and got the blocks for 3" leaves and I needed 2.5" . No problem--I have a chop saw!
I used the 1.5" backspace hole---you have a choice of one inch or one point five inches. It seems my 1 to 2 hour project has turned into a 2 week project. By moving the axle back 1.5" it make the driveshaft too short. I will have to take it to Amarillo (3 hours ) to have it lengthened. Also, the emergency brake lines are really tight. I am going to have to move the brackets back. Unfortunately they are riveted on. Any suggestions? On the bright side, it did center up the wheels in the wheel well. It was dark outside, so I had to take the pictures in the shop. Here's for all you pic sluts-----enjoy!!!
04-05-2008, 08:23 AM | #23 |
A few more
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 04-05-2008 at 08:27 AM. |
04-05-2008, 08:29 AM | #24 |
Well, Whoop-dee-do!
Sure does look better centered
I have to move my ebrake cable frame brackets as well- haven't got it done yet. I grind the rivet heads off, then beat them out using a flat- ended punch of slightly less diameter. Keep in mind to relocate them far enough down &/or back to allow slack for full axle droop.
04-05-2008, 08:32 AM | #25 |
Thanks Jeff,
Are you going to weld or bolt your brackets back on? john
Thread Tools | |
Display Modes | |
