Old 03-24-2008, 01:10 AM   #1
pissonNOS
senior member
pissonNOS's Avatar
what size tire should i run up front
i just finished installing my disc brakes and drop spindles on my truck this weekend but when i aired it out the tires are hitting the outside of the tire pretty good, right now i have 275/60/15's all the way around so what size should i put up front to remedy this? oh also there 73-87 4x4 rims if that helps
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 03-24-2008, 03:05 AM   #2
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: what size tire should i run up front
I put some 235/70-15's on the front of my "work" truck (Same height as the 275/60-15). They are a little skinny on the 8" rallies but they are much better as far as clearance issues go.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 03-24-2008, 04:56 AM   #3
72 cheyenne pdx
72 cheyenne pdx's Avatar
Since you have 4x4 rims, I would go with some 42" swappers.:lol
How much is hitting? You may be able to fit some 255/65/15's in the front. They are also in the same range you are in now. If not, the 235's should work.
72 cheyenne pdx is offline   Reply With Quote
Old 03-25-2008, 07:57 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
quite a bit is hitting i can tell the bag isnt fully deflated, i think i need a less wide and a lower profile tire if that makes sense but i dont known how tire numbers go
69 GMC bagged
Old 03-26-2008, 05:45 AM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
The first number is the width of the tire, the second number is the sidewall ratio or height and, obviously, the last number is the rim size.
The 275/60-15's measure 28" tall.
Here are some examples of BFG Radial T/A's that might work
235/70-15's are the same height (28") but are much narrower.
245/60-15 are not quite as narrow as the 235's but are only 26.6" tall.
All kinds of options with tires... You will probably spend hours searching, I know I have.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 03-26-2008, 05:46 AM   #6
pissonNOS
senior member
pissonNOS's Avatar
thanks, i just dont want something too skinny
69 GMC bagged
Old 03-26-2008, 08:41 AM   #7
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
The 245's should look pretty good on 8" rallies. It's a good compromise... just a little narrower and slightly shorter which should help with your clearance issues.
1978 Chevy C/10 SWB
1970 Pontiac Lemans
Old 03-26-2008, 05:31 PM   #8
Shane
Shane's Avatar
Now that you have the dropped spindles, I think the 245's will cause some draggin issues with the lower control arm.
Shane is offline   Reply With Quote
Old 03-27-2008, 06:53 AM   #9
pissonNOS
senior member
pissonNOS's Avatar
i was kind of wondering about this as well i got my wheel alignment done today with 80PSI and it sits quite high but i think im going to try and put a couple different tires on this weekend and see where were at
69 GMC bagged
Old 03-27-2008, 09:42 PM   #10
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
235/60/15 front or both
275/60/15 rear
works on a bagged C10 well.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Thread Tools
Display Modes
