03-26-2008, 06:32 PM | #1 |
1970 Daily Driver
Need Advice
I was hoping to get some advice from you guys on putting vintage air in my 70 c-10. If I don't order my system by March 31st the price goes up $150 because of their price increase.
I have a 327 in my truck now that is great but when it gives up down the road I plan on upgrading to the new 5.3L and a 4l60e or a LQ9. So my question, do I get the A/C now or do I wait it out for the new motor? Has anyone had a vintage air system with the older engine and then converted it to work with the engines of today? I just don't want to buy it now to save a $150 and then turn around a couple years later and have to spend three times that converting it to work with a newer motor. But then again if I can save $150 now and it only costs me $150 down the road to convert it over I would get it now. Thanks Guys
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
03-26-2008, 06:51 PM | #2 |
Re: Need Advice
call vintage air and ask them about what would be the difference for the 2motors,i'd think it would be a common problem that they have a solution for
03-26-2008, 06:58 PM | #3 |
Re: Need Advice
you would probably have to rig up the new compressor, if even that, and have the system recharged, but you should call them and find out b4 spending any money, but u are going to want A/C this summer.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-26-2008, 06:58 PM | #4 |
1970 Daily Driver
Re: Need Advice
I just called them and they said I would have to use a compressor that is for the newer engine, re-crimp new fittings that go to the compressor if the hoses are long enough, if they are not replace hoses, and they recommend replacing the dryer when switching out compressors. What do you guys think, is it worth it?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 03-26-2008 at 07:00 PM. |
03-26-2008, 07:03 PM | #5 |
Re: Need Advice
so that is about $200, mabye $300? that's worth getting it now and fixing it later to make it fit, i say be comfortable this summer and get it now, and just spend the little extra money later to make it fit.
03-26-2008, 07:05 PM | #6 |
Re: Need Advice
Is the truck your DD or a weekend cruizer?
03-26-2008, 07:11 PM | #7 |
1970 Daily Driver
Re: Need Advice
That is what I was hoping you guys would say. I just needed to hear it from some one else.
When I emailed vintage air they gave me a price of $1,162.79 for their surefit system with a modified coil to run a 4-way bulk head, including the bulkhead and provisions to run a smooth fire wall out the door price. When I just called them up the sales representative quoted me $1295. So I dont think their prices are set. Has any one been able to get them come down in price? If so how much? It is a Daily Driver.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. Last edited by lts70; 03-26-2008 at 07:12 PM. |
03-26-2008, 07:21 PM | #8 | |
Re: Need Advice
When you buy the new gen motor, get it COMPLETE and you will have a "free" A/C compressor. My truck has 112K and is 8 years old and it still blows ice cold. Just get new fittings and you'll be done If your VA compressor is fairly new, you can sell that as well....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 03-26-2008 at 07:22 PM. |
03-26-2008, 07:30 PM | #9 |
Re: Need Advice
I really think they are all wet The only differance should be changeing the compressor pully for the serpintine belt and maybe some brackets. hardly $300 worth. The new kit and compressor should be for 134a all ready. If you use your old compressor you can change over to 134A for about $100
69 Chevy 4x4 383 Power |
03-26-2008, 07:48 PM | #10 |
Re: Need Advice
It also a new dryer, and they don't give those away free, and i'm sure 134 is what Vintage Air uses
03-26-2008, 08:13 PM | #11 |
Re: Need Advice
Bought my dryer at napa fo $40 the dryer is like a filter and should be replaced every couple of years.
03-26-2008, 08:37 PM | #12 |
1970 Daily Driver
Re: Need Advice
Thanks guys for all of the feed back. I am going to order it today.
I already have a factory a/c controller, 4-core radiator, electric fan, and a three groove water pump pulley. Do I need a 3 grove crank pulley or is there an adaptor that will add one more groove to my original crank pulley. I do have power steering. Is there any thing else I need?
Thread Tools | |
Display Modes | |
