Old 03-26-2008, 10:12 PM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
License Plate Lamps Wont Work
I have no idea what is wrong. I have used a tester grounded to the frame, and there is no power getting to the lights. Any possible ideas? Every other light works. I cant find where the wire goes though.
Thanks for the help, I really appreciate it,
Jared
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 03-26-2008, 10:45 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: License Plate Lamps Wont Work
Most L.P. lights I have seen no working was due to poor grounding. Pull it out, brush it, and stick it back in, IF the bulb Ohm's out ok. If all else fails, run a new wire up to a tail light and tap into the harness. Just be careful not to tap into the brake/turn signal wire....
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-26-2008, 10:47 PM   #3
SRH916
SRH916's Avatar
so the ground is the tail light itself?
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 03-26-2008, 10:50 PM   #4
babyJay
babyJay's Avatar
The one wire going to the bulb is 12 volts positive, the outside of the bulb lens casing, usually chrome, is the ground. That casing has to be touching the grounded part of the vehicle for it to work.
Jason
89 R3500 CC SRW
Old 03-27-2008, 12:17 AM   #5
SRH916
SRH916's Avatar
Thanks for the help, now that I know how that all works, I should be able to get it fixed.
I really appreciate that, now maybe I can drive after the sun goes down
Jared
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Thread Tools
Display Modes
