Old 03-28-2008, 04:16 AM   #1
shortbed70
shortbed70's Avatar
72 arms and spindle fit?
Ok I was going to do the whole crossmember then decided not to so I took the upper\lower control arms and spindles off a 72 and when I took them apart to clean them up the lowers are shot so my question is can I use the uppers and spindle from the 72 on my 65's dropped lowers? Can I run the same balljoint or ream the spindle to fit? I've done a search but I've never really found a direct anwser to my question. Thanks.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-28-2008, 04:44 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 72 arms and spindle fit?
I wouldn't try to ream the spindle. Just use the '72 lower balljoint. You will need to adapt the tie-rods as well...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-28-2008, 04:58 AM   #3
shortbed70
shortbed70's Avatar
Ok I can do that a balljoint is cheaper than a lower arm. I plan on using all the steering stuff from the 72 draglink,tierod ends idler etc. Thanks
Troy
Big Red Dog build
Thread Tools
Display Modes
