Old 03-28-2008, 06:12 AM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Cluster Light Problems
I have all my other interior lights working now except for my cluster lights...I noticed in the fuse box there is a spot that reads cluster feed---is that what I'm missing or any ideas???
1971ChevyTruck is offline   Reply With Quote
Old 03-28-2008, 07:11 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cluster Light Problems
cluster feed would be to wire in aftermarket guages, so they would dim with the rheostat.
Old 03-28-2008, 08:59 AM   #3
dan42
dan42's Avatar
Check this one - http://67-72chevytrucks.com/vboard/s...d.php?t=284861
and this one - http://67-72chevytrucks.com/vboard/s...d.php?t=284477
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-28-2008, 02:40 PM   #4
1971ChevyTruck
I have tried extra grounds...everything...which copper leads on the harness connector should have juice for the lights --on the plug that plugs into the cluster--I even cleaned the heck out of all the copper leads...I'm lost...
Old 03-28-2008, 02:42 PM   #5
1971ChevyTruck
I checked and I do have tail lights which is on the same fuse as the cluster light--so I have been told---so what now??
Old 03-28-2008, 03:03 PM   #6
70GMCer
70GMCer's Avatar
Have you checked circuit continuity on your printed circuit board with a meter? You may have a bad board.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-28-2008, 03:11 PM   #7
1971ChevyTruck
No..I haven't done that yet...but I have tried two seperate boards...the only light that comes on is the turn signal--but that is very weak--I would think it was a ground but I have tried extra grounds through wires, alligator clips, and even tried touching the darn thisn to the dash to ground it...I have all new fuses, new dimmer switch, new headlight switch, new dome light, new everything. I even found the factory ground and its working...
Old 03-28-2008, 04:51 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Since you have eliminated the possibility of a ground problem and parts failure, you need to check for voltage. I'd start with "U" shaped connector and check to make sure you have the 12 vdc needed and work yourself up to the instrument panel connector.
If your lights are weak it's possible you may have a high resistance on one of your feed wires.
Let us know what you find...
68gmsee is offline   Reply With Quote
Old 03-28-2008, 06:14 PM   #9
Longhorn Man
the U shaped plug has nothing to do with the inst panel, that's just brake lights and turn signals.
Old 03-28-2008, 07:37 PM   #10
70GMCer
70GMCer's Avatar
also make sure that plug that goes into the circuit board is clean and making good contact......
1997 GMC Sierra Ext
1965 Mustang
Old 03-28-2008, 08:45 PM   #11
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
May want to look at the head light switch. Might be goining bad.
jayharrell is offline   Reply With Quote
Old 03-28-2008, 09:14 PM   #12
1971ChevyTruck
Headlight switch is brand new...cleaned the contacts snd still nothing
Old 03-28-2008, 09:43 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Panel lights aren't turned off at the headlight switch are they? (rotate headlight switch knob)
LockDoc
Leon
Old 03-28-2008, 10:29 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
LockDoc
They are actually.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-29-2008, 05:53 AM   #15
1971ChevyTruck
I give up...Tried everything again tonight...
Thread Tools
Display Modes
