Old 03-29-2008, 01:32 AM   #1
pat123
Pat
pat123's Avatar
need some help
what in are the torque specs for cab mounts on a 69 chevy 1/2 ton?
thanx
pat123 is offline   Reply With Quote
Old 03-29-2008, 02:09 AM   #2
powell72
powell72's Avatar
Re: need some help
My service manual says 20 ft.lbs. for the radiator supports and front cab mounts and 50 ft.lbs for the rear cab mounts. That doesn't seem tight enough to me?
I just make them nice and tight and call it good.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-29-2008, 02:22 AM   #3
pat123
Pat
pat123's Avatar
Re: need some help
cool thanx
Old 03-29-2008, 02:22 AM   #4
463
463's Avatar
Re: need some help
thats why there called "torque specs ". you feel that it may come loose feel free to put on thread locker on and re torque to the specks. it works.
Trueman
463 is offline   Reply With Quote
Old 03-29-2008, 03:32 AM   #5
JimKshortstep4x4
Re: need some help
My manual give the specs as 20 lb.ft. for the radiator support and 50 lb.ft. for the number two position. The number three position being the rear on a truck is 20 lb.ft. The mounts are numbered by position starting from the front with the radiator support being number 1.
The radiator support position #1 and position # 3 mount bolts are 7/16-14 bolts whereas the large bolts in #2 position are 9/16-12.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-29-2008, 03:55 AM   #6
crazy longhorn
Fabricate till you "puke"
Re: need some help
I go 3/4 past strip, then back em off 1 full turn IIRC, the cab mounts have sleeves in them, making it hard to "overcrush" the rubbers. I would stick to the book specs, & maybe run the truck for a while & recheck em crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-29-2008, 05:14 AM   #7
powell72
powell72's Avatar
Re: need some help
I'm a mechanic though, I torque stuff with my impact, no time to dig out the torque wrench.
Chris
Thread Tools
Display Modes
