Old 10-30-2002, 07:47 AM   #1
scalawag
quad. question
fellas how much warpage is alllowed on the airhorn. i'll draw file it but i just wanted to know how much is allowable. and can i do away with the secondary lock lever.
scalawag is offline   Reply With Quote
Old 10-30-2002, 08:15 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I guess you are meaning warped as in where it bolts up. I figure as long as it doesn't leak, it will be ok. And yes, you can remove the lockout tang. All this is for is to keep the secondaries from opening until the engine is warm. Sometimes these things will stick and not let the secondaries work at all. I always remove mine.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-31-2002, 08:04 AM   #3
scalawag
thanks mike
thanks man. i am building this sucker from the ground up. and if you read this. how much play is allowable in the throttle shafts?
Thread Tools
Display Modes
