03-30-2008, 06:54 PM | #1 |
built not bought
01 yukon denali stalling
hi all, iv got a bit of a problem with the wifes daily driver. this happens to her way more than i happens to me, but this is what happens. the rig is an 01 yukon denali with the 6.0 and when she turns slowly it will stall. i think once it stalled when she stopped at a stop light. it doesnt happen every time but it happens enough to be a problem. also when it idles it seems idle very low. my cousin has a 03 denali with the same motor with a similar problem that he has not addressed yet. if any of you have some ideas or the same problem, post up. thanks
04-02-2008, 05:46 AM | #2 | |
Re: 01 yukon denali stalling
04-02-2008, 07:31 AM | #3 |
Truck and auto performance nut
the genIII motors (and the 6.0 in particular) are bad about fouling up the throttle body with carbon and crud. This really jacks with the drive by wire systems like in your Denali.
Remove the air intake tube from the throttle body and clean inside and out (both sides of the blade, especially the edges) with throttle body cleaner. put it back together and enjoy.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-21-2008, 11:15 PM | #4 |
built not bought
ok, so i cleaned the intake out. cleaned the blade, outside the blade, and inside best i could bout a week ago. so far no stalls, and it seems to idle a bit higher now. and best of all, way less boobin from the wife thanks for the input!!
04-22-2008, 06:20 AM | #5 |
glad to help!
04-23-2008, 04:54 PM | #6 | |
05-23-2008, 08:29 AM | #7 |
My 02 Avalanche 2500 is doing the same thing, I will clean the TB and see if that works, mine is the Big Block, but shouldn't make any difference. Will let you know if it works. Thanks, Neal
05-24-2008, 02:42 AM | #8 |
if its got the drive-by-wire type throttle body...then yes you could have the same issue.
Thread Tools | |
Display Modes | |
