Old 03-31-2008, 08:33 AM   #1
Sicmaro
Always wrenching!!
Sicmaro's Avatar
5.3L...... which manifolds???
i just put a 2004 5.3 and 4l60e, i see the 98 camaro manifolds fit. i also see lots of pictures of you guys with the stock truck manifolds. my 2004 tahoe manifolds seem to hit the factory pedistal for the motor mount. i also have c5 vette manifolds. any help would be great!!!!
trying to build this with out spening any money haha!!!! real low budget build.
and just another one i took.......
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 03-31-2008, 08:49 AM   #2
ed2552
ed2552's Avatar
Re: 5.3L...... which manifolds???
Why is there a quad in the back? You rle like Gen III motors, don't you?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-31-2008, 09:06 AM   #3
Sicmaro
Always wrenching!!
Sicmaro's Avatar
its the only place to store it right now haha
and, yes! they are the best motor out there!!!
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 03-31-2008, 09:08 AM   #4
ed2552
ed2552's Avatar
My dad's 02 Suburban has the 5.3 and it is a good truck, but is even better with the K&N intake
Old 03-31-2008, 04:55 PM   #5
Custom 68
Custom 68's Avatar
I am running some from a ls6 from a z06 vette. They look like shorties. Car craft did an article that compared them to long tube headers and they did very well, others will agree that headers with a proper tune will be much better but I am happy with my choice. Stock with a tune I made almost 300 rwhp and 300 rwtq. I am now putting in a larger cam so we will see.
Any of the manifolds will bolt up just getting one to fit is the problem.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-31-2008, 07:04 PM   #6
shifty
Questionable
shifty's Avatar
'98-00 F-body manifolds. Fit for me without grinding.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-31-2008, 09:08 PM   #7
Ackattack
Ackattack's Avatar
Camaro Long tube headers for me
Ackattack is offline   Reply With Quote
Old 03-31-2008, 09:58 PM   #8
stonewall618
Just loves his truck.
stonewall618's Avatar
looks like a manifold you would put on a BB
Gold 1969 c10 LWB--350 gm crate motor 30"muds on the back...with aluminum rims with black and red Chevy bowtie center caps that look awesome!
EAGLE SCOUT FTW!!!
stonewall618 is offline   Reply With Quote
Old 04-01-2008, 01:02 AM   #9
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Dave
do you have pics? what motor mount are you using?? it seems like my first primary tube is hitting the mount.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 04:09 AM   #10
Sicmaro
Always wrenching!!
Sicmaro's Avatar
OK!!!! i tried the 2000 camaro manifolds and they also hit the motor mount! what mounts are you guys running?? every manifold i try hits the damn mount. PLEASE HELP............
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 04:13 AM   #11
Sammy
Won't the old style turnback stock 307/350 miss the mount?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-01-2008, 04:23 AM   #12
Sicmaro
Always wrenching!!
Sicmaro's Avatar
with the new 5.3l?? the exhaust ports and bolt pattern arnt the same.
Are most of you guys running aftermarket or diff. year frame side mounts??
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 04:32 AM   #13
Sammy
I didn't know. they fit my Vortex 350 just fine..
Old 04-01-2008, 04:42 AM   #14
Sicmaro
Always wrenching!!
Sicmaro's Avatar
OHHHHHH, yeah with the vortex they would. the new gen III exhaust ports are more designed like a ford head.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 04:57 AM   #15
Sammy
That sucks big. Someone should be able to help, has to be a header that would fit your app then.
Old 04-01-2008, 05:03 AM   #16
Sicmaro
Always wrenching!!
Sicmaro's Avatar
im sure there is, trying to not spend money haha. the driver side truck manifold fits, my need some grinding just for clearance but the passenger is being a b*t*h haha
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 05:05 AM   #17
Hart_Rod
Hart_Rod's Avatar
Here's a set of Doug Thorley "proto-type" headers that I'm test fitting on my 69 Suburban (5.3/4L60E). They fit great and should add some decent horsepower. I'll probably run the 98-00 F-body manifolds on my 67 CrewCab since it's not going to be a show truck. I've got an extra set if decide to go that route.
Hart_Rod is offline   Reply With Quote
Old 04-01-2008, 05:22 AM   #18
Sicmaro
Always wrenching!!
Sicmaro's Avatar
ya Ive got a set of the 00 f-body manifolds. the truck ones fit better then they do. the only difference i see is that you are running different motor mounts. I'm still using the stock frame side mounts. the manifolds are hitting the hump in them.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 05:24 AM   #19
Sammy
Those headers look sweet in there HartRod.
Old 04-01-2008, 05:40 AM   #20
Hart_Rod
Hart_Rod's Avatar
Thanks, the quality and fit is outstanding.
Do you have pictures of the Fbody ones you have? They should better than the truck ones (or at least mine do).
R/
Old 04-01-2008, 05:47 AM   #21
Sicmaro
Always wrenching!!
Sicmaro's Avatar
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 05:51 AM   #22
Sicmaro
Always wrenching!!
Sicmaro's Avatar
00 f-body
C5 vette
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 05:55 AM   #23
68 short step
you know what you need to do, either mod the ones you have... or save your pennies and get tubular ones from performanceonline.com....IIRC they are about 100$
68 short step is offline   Reply With Quote
Old 04-01-2008, 06:09 AM   #24
Sicmaro
Always wrenching!!
Sicmaro's Avatar
guess im modding them haha. tryin not to spend any more $$$. building with what i got!!! HOPEFULLY haha
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
Old 04-01-2008, 06:14 AM   #25
Hart_Rod
Hart_Rod's Avatar
Here's some information on the factory manifolds that Shifty posted (pic included):
The set of ’98 Camaro/Firebird manifolds (top) worked best for us (PN 12567706 RH, 12559507 LH). Other possibilities include ’99-’03 Camaro/Firebird (second from top), ’99-’03 C/K Silverado (second from bottom), and ’97-’03 Corvette (bottom). These manifolds have 2 1/2-inch outlets that Cole was able to build a complete exhaust off of.
Thread Tools
Display Modes
