Old 10-30-2002, 06:52 PM   #1
72gmcshorty
72gmcshorty's Avatar
Question Rad fan ??? and HEI ???
I have a new 4 core rad and a BB motor. I have no fan shroud and was wondering what I should do for a fan? Should I use a regular stock 70's style 4 blade metal fan or a clutch style fan and find a shroud or what else? I don't want to spend the money on an electric fan setup unless I can't find a shroud.
HEI question- What size wiring should I use to go from the distributor to the fuse panel?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-30-2002, 07:26 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
As far as the BB/fan shroud combo, I can't help.
For the HEI, I used 10 ga. Most people will tell you this is overkill, but it's better to have a wire that's larger than suggested, than to have a wire that is too small and gets too hot. From what I have heard, 12 ga. is sufficient.
Good luck,
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-30-2002, 09:01 PM   #3
crazy longhorn
Fabricate till you "puke"
I 2nd that, i also have a 10 guage wire to my HEI. If you are running an engine driven fan, a shroud is a needed item. I prefer a flex fan over the clutch fans, & have run a flex a lite plastic fan with good luck on anything from a 327 chev to a 455 Olds. Do be careful not to buzz the throttle while standing over the engine. Good luck......crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-30-2002, 11:06 PM   #4
wbmorris87
Best Electric Fan Set up is a 1992 Furd Escort. They are 2 speed, and by far move more air than any other. I use these in my stock car. A 4 blade fan works well to though, I use one of these and a shroud out of a Nova for my wifes stock car. I am putting the electric fan setup on my 69 4X4 Conversion when the time comes.(in about 2 months god willing) A lot less noisy.
wbmorris87 is offline   Reply With Quote
Old 10-31-2002, 12:28 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have a clutch fan on my small block with no shroud...only an inline finger protector. It gets about 10 degrees warmer in traffic than the T-stat's rating.
Try it while you look for a shroud. It's getting cold out now anyways. Just make sure your temp guage works, and you'll be fine.
Old 10-31-2002, 02:31 PM   #6
neonlarry
neonlarry's Avatar
I'm interested in using the ford electric fan. Does anyone have any pictures of one installed, and information about the wiring?
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Thread Tools
Display Modes
