Old 05-06-2002, 11:46 PM   #1
primer67
primer67's Avatar
Post AAAAAAAAAAAH! never again do I want to look at rearend components!
I took apart the rearend today, spent 7 hours crawling around in the 100 degree heat !!!!!!! 'till I finished it. -- the ring and pinion from the old unit had 41 teeth from the ring, and 12 teeth ( I think ) from the pinion. does that make sense? - cause the rearend I bought from a recycler guy had 37 teeth on the ring and 9 0n the pinion; so I had to first drive the pin with a punch, cause the bolt was broke off inside, then I had to cut the pin in the existing rearend with a torch, then I had to re- thread the set pin hole, remove the ring gear off of the old unit,(took 2 hours with a mini sledge) remove the ring gear from the new unit, and then put the old ring gear on it. 100 degrees! wearing mostly gear oil, and jeans. finally I had it all together, and the stupid set pin wouldn't fit in the carrier pin! - some guy walked over to me after watching me for a few, and handed me a brand new looking carrier pin.- he said "try this" - damn... some nice people are still around. _on a dif, subject, there were about 5-6 67-72 parts trucks there - One had a custom chassis and aftermarket disk setup -- I was tempted! -all will go cheapo too!
1967 C-10 Longbed
rollpanned front&back
Cowl induction hood
'91 5.7 liter/vortec heads, 700r4 trans. holley headers,
holley fuelpump,
holley mufflers. converted to edelbrock performer/carter 625
hei/advanced recurve
MSD 6A ignition box.
Accel supercoil
Accel custom 8.8 wires
5 bucks a plug even!
faster!!!!!!!!!!!!!
soon to be lowered "a little" looking for a good tonneau cover.
primer67 is offline   Reply With Quote
Old 05-07-2002, 12:19 AM   #2
AZ68
Post
I know your pain -- finally done with truck enough to go to paint shop
-- !#@$!%$@#^% body panels !!#$@%@$%&^ hood
!@!#@$%#^%$%^doors glad to hear your up and running again hang on rto those parts for me.
Im coming soon -- Bob
68 c-10 lwb to swb 383 lr stroker 700 r4 starting frame off now
phoenix, arizona
AZ68 is offline   Reply With Quote
Old 05-07-2002, 12:45 AM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Post
Ouch, pain, but dang that 100 degree heat don't sound too bad to me. It was snowing today and the wind was blowing cows by the window.
Better grab that aftermarket disc setup quick
Scrub
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
Scrub is offline   Reply With Quote
Old 05-07-2002, 01:36 AM   #4
primer67
primer67's Avatar
Post
you got it Bob.
Now I'm rethinking a way to get a posi! - after all that and I still haven't learned my lesson!
Thread Tools
Display Modes
