04-11-2008, 06:36 AM | #1 |
headers for bagged trucks
im trying to find some headers for my truck that dont go below the frame rails, i got some patriots that i thought would fit but they hit the engine mounts. im told block huggers shouldnt be used because the front crossmember will be in the way.. would regular headers work with my 2 1/2 inch Z? need some help... thanks
Steve |
04-11-2008, 06:41 AM | #2 |
Daily Driver
Re: headers for bagged trucks
im told that some shortys for a 82-92 camaro work
nitrous...the equal opportunity destroyer. |
04-11-2008, 06:44 AM | #3 |
ive also heard chevelle shorties will work but is there anyone that is using them or knows for sure
04-11-2008, 06:50 AM | #4 |
These are what we run (this part number is for the NON-ceramic coated)
Hooker headers part# 2466HKR
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-11-2008, 06:51 AM | #5 |
and will these clear stock mounts?
04-11-2008, 06:54 AM | #6 |
IIRC there's plenty of room... let me get some pics to post tomorrow.
04-11-2008, 06:56 AM | #7 |
what im worried about is the front tubes on # 1 and 2 cylinders. thats where they would hit the mounts if there was an issue
04-11-2008, 07:01 AM | #8 |
http://67-72chevytrucks.com/vboard/s...=211503&page=3
There's some good pics a couple posts down the page.
04-11-2008, 07:29 AM | #9 |
A guy with a truck
I am using the Chevelle 3/4 lengths, but I switched to the 73-87 style engine mounts. Plenty of room...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-11-2008, 07:44 AM | #10 |
i found some that look like they would work but it says "chevy v8 conversion 87-95".
my heads are 86, are the exhaust ports and bolt holes different? |
04-11-2008, 08:25 AM | #11 |
The exhasut ports on the SBC are all the same.
04-11-2008, 06:19 PM | #12 |
So when you use these headers do you run into any problems or any close calls? For example: the steering linkage is really close to the headers but they still clear, that sort of thing.
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
04-11-2008, 06:32 PM | #13 |
A guy with a truck
Those are the Jeep conversion headers. I've heard of some guys on here using them, but I don't know how the fit is...
04-11-2008, 07:14 PM | #14 |
Junior Member
I'm happy with mine. Hedman 69640 shorty headers...
04-11-2008, 08:05 PM | #15 |
It'd be alot cooler if you did
I'm going to get a set of these when I start putting the truck back together. Have to get the paint work done first though!
http://cgi.ebay.com/ebaymotors/CAMAR...QQcmdZViewItem |
04-11-2008, 08:16 PM | #16 | |
A guy with a truck
04-11-2008, 08:21 PM | #17 | |
04-11-2008, 08:25 PM | #18 | |
04-11-2008, 08:25 PM | #19 |
A guy with a truck
You can polish the silver paint looking ones too, just like you would polish aluminum. Dunno on the limited quantity- I do know that I've had mine for a while and they're still selling them...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-11-2008 at 08:26 PM. |
04-11-2008, 08:46 PM | #20 |
they have an ongoing auction for them every time I look, but I guess you never know.
04-11-2008, 11:59 PM | #21 |
Active Member
What motor mount towers are those Gringo? And do you have a picture from the bottom?
04-12-2008, 02:10 AM | #22 |
gringo, thats what i was going to ask,, it looks like those motor mounts are different then mine
04-12-2008, 05:49 AM | #23 |
Active Member
I re looked at the post of his and they are 73-87 motor mount brackets. But would still like a pic of the bottom to see how low they hang.
04-12-2008, 06:04 AM | #24 |
ok so they wont work with the brackets from a 67-72...the front tubes will hit the mounts
04-12-2008, 05:39 PM | #25 |
Active Member
That is what I am thinking I know the towers on the 67-72's sit higher, but man that is a good deal on headers!
Thread Tools | |
Display Modes | |
