Old 10-31-2002, 08:58 PM   #1
72gmcshorty
72gmcshorty's Avatar
Question Battery cables
From the battery, where does the positive go to and where the negative?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 10-31-2002, 09:05 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
72, the pos cable runs form battery down to starter larger hot post and neg cabe runs form battery to engine block with a bolt and bolt hole, i like to run another cable from engine block to frame rail in engine compartment and sometimes from there to fender or firewall. 3/8" bolts are great for this and 3/8" drill bit, you can get the copper crimp on 3/8" loop end connectors from auto parts stores cheap, i always use cables laying around and cut off the batt terminal end and connect copper ring end on when using them as grounding straps/paths for body to ground to engine, too much ground is impossible to have.
good luck
Fast68Chevy is offline   Reply With Quote
Old 10-31-2002, 09:05 PM   #3
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Positive goes to the positive on the starter solinoid.
Negative on my truck bolts right to the head on the pass. side of truck
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 10-31-2002, 09:07 PM   #4
jhow66
jhow66's Avatar
Battery positive to large post on starter
Battery negative to ground on motor . ( be sure and ground motor to frame and motor to body.)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-01-2002, 01:24 AM   #5
Hooter
My other Love
Hooter's Avatar
I agree one can never have too many grounds. Even on my ford there is a ground strap on the hood. I dont know why maybe because fords are stupid
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Thread Tools
Display Modes
