Old 04-15-2008, 04:54 PM   #1
gottwake
gottwake's Avatar
Front X-member notch question
The truck that I bought has this notch in the front crossmember, it's 1.5". The work is good but am i going to have clearance problems with the motor or anywhere else?
Blazer Project
gottwake is offline   Reply With Quote
Old 04-15-2008, 04:59 PM   #2
jlaird
jlaird's Avatar
Re: Front X-member notch question
you will have clearance issues with your inner tie rod ends.
jlaird is offline   Reply With Quote
Old 04-15-2008, 05:09 PM   #3
gottwake
gottwake's Avatar
Whats the fix?
Blazer Project
Old 04-15-2008, 07:05 PM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Also, the motor mounts will be screwy, as it's a notch and not a cross member section. The mounts will have to have some creative engineering done to them.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-15-2008, 07:16 PM   #5
gottwake
gottwake's Avatar
okay...so how much do i need to section in order to avoid problems??
Blazer Project
Old 04-15-2008, 07:57 PM   #6
XXL
Señor Member
XXL's Avatar
Based on the one pic, it's hard to see what mods were made. If it's just a notch, and not a section as lowrollin70gmc suggests, you'll run into a number of issues... tie rods and center link clearance, engine height (unless you chop down the motor mount stands, in which case you may have oil pan clearance problems), etc. The proper method for modifying the xmember "like that" is to use Captkaos's method (search). Mine is done that way (by Catkaos, actually) at 1.5" and I don't have clearance problems, but others have reported slight clearance issues with a 1.5" cut, and so have gone for slightly less.
XXL is offline   Reply With Quote
Old 04-16-2008, 01:26 AM   #7
jlaird
jlaird's Avatar
First thing you have to ask yourself is how low do you want to be and how much money you want to spend to get there. The other key factor is if you know how to weld.
If you don't want to lay frame, I would ditch that crossmember and get one out of a 73-87 with front disks. Get yourself some drop spindles, bag plates and hit the road.(just talking about front suspension here)
If you have some money to spend and want to lay frame, get the dropmember.
If you want to lay frame and are on a budget, well... get out the welder!
Old 04-16-2008, 08:04 PM   #8
HotRodYJ
HotRodYJ's Avatar
Notch the frame for steering clearance and just raise the motor 1.5". Shouldn't run into much problem at all just raising the motor 1.5". And I'd box in the frame for strength at least at the crossmember section.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 04-16-2008, 08:35 PM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
OK, this is how mine is dropped raised and there is absolutelty nothing wrong with it. I do not have oil pan clearance problems AT ALL, and the engine is in the stock location. Raise all the steering components up 1.5 inches, notch the frame to clear it, redo the steering shaft, and chop the motor mounts. thats it. done.
here's some old pictures from when I did mine.
The cut out in the frame has a traditional looking 1/4" steel "c-notch" on the inside of the frame rail where the tie rods are.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-16-2008, 08:48 PM   #10
XXL
Señor Member
XXL's Avatar
Depends on your motor. I can't speak for all V8's, but the 250 and 292 inline 6's WILL have oil pan clearance problems. Also, for TH400 transmissions, you may run into clearance problems with the trans tunnel when you raise the motor up that much. Oh... and HEI may be an issue as well.
Old 04-17-2008, 06:46 AM   #11
smashingchuck
but, but, but....
I'm not trying to start an arguement here, but I know what I have done on my truck and I know what works. My motor is not raised up, as I have chopped the motor mounts down so the motor sits in the stock location.
78 Build Thread
4Runner Build
Old 04-17-2008, 07:26 AM   #12
gottwake
gottwake's Avatar
Okay...If i dont choose to buy a dropmember, cant I notch the frame for steering and notch where the oil pan goes if it becomes an issue?
As for a trans, 700R is what I have.
BTW, I do welding on public works projects.
XXL,
Whats HEI?
Blazer Project
Old 04-17-2008, 07:36 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
I don't think you're going to have to raise the motor much, if any. But since the crossmember is raised up 1.5" you will also need to move the idler arm, and steering box up the same distance to keep the steering geometry where it needs to be.
If you're not wanting to lay frame, you should be able to make this set-up work without spending too much money... just some time.
HEI is the electronic distributor with the coil mounted in the cap... it's a little bulkier than the original points style.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-17-2008, 07:49 AM   #14
smashingchuck
that's why mine is raised up the same amount as the crossmember - eliminates a would be bumpsteer problem.
78 Build Thread
4Runner Build
Old 04-17-2008, 04:37 PM   #15
gottwake
gottwake's Avatar
I dig this place! thanks guys...
Blazer Project
Old 04-17-2008, 05:41 PM   #16
XXL
Señor Member
XXL's Avatar
but, but, but....
Seems like maybe you are. I ALSO know what I've done on my truck, and I know what works. As it turns out, not all trucks are identical to one another... especially since, if you're referring to the one in your avatar, some aren't even the same body styles.
That is all.
Thread Tools
Display Modes
