Old 04-16-2008, 06:41 PM   #1
truck junky
Cool air valves ???
Iam getting ready to buy my air valves for my suspension but I don't know which kind of valve system I want to go with. Any suggestions and pics would help.
truck junky is offline   Reply With Quote
Old 04-17-2008, 12:53 AM   #2
jlaird
jlaird's Avatar
Re: air valves ???
I would be looking at an 8 valve setup which is basically a fill and dump valve for each bag. Take a look at some plumbing diagrams to familiarize your self with how they work. Another option which is more simple and clean looking is a manifold which is basically all 8 valves plumbed together on one block. Air Ride Tech makes one as well as another company that is escaping my memory right now.
jlaird is offline   Reply With Quote
Old 04-17-2008, 02:17 AM   #3
Swifty
Swifty's Avatar
Re: air valves ???
Last edited by N2TRUX; 04-17-2008 at 05:02 PM. Reason: You must be a subscribing member to post any item for sale.
Swifty is offline   Reply With Quote
Old 04-17-2008, 02:20 AM   #4
tds
Re: air valves ???
what size line are you gonna use? what kinda speed are you looking for?
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 04-17-2008, 02:48 AM   #5
truck junky
Cool Re: air valves ???
Iam going to use 3/8 hard line for most of it. thinking I want to us a manifold setup to keep everyhting together. But am open to other poeple suggestions. If your wondering Iam building a 61 truck that has a 77 crossmember with air ride upper and lower control arm and has been z'ed 3 inches. In the rear i made a big notch for the axle clearance with a four link setup. For those of you who know about the 60-62 frames Iam cutting out the inner frame webbing and boxxing the frame and adding new frame supports.
Old 04-17-2008, 03:08 AM   #6
jlaird
jlaird's Avatar
Re: air valves ???
you going stainless line or??? Where are you getting the fittings from for the hardline?
To anybody else, can you run aluminum line for air?
I want to do stainless hardline but I've been reading over on the s10 forums from people that have done it that it costs around $1000 for tubing and fittings after all is said and done. Thats WAY to steep for me.
Old 04-17-2008, 05:13 AM   #7
abadsvt
abadsvt's Avatar
Re: air valves ???
I ran some alluminum air lines for my chevelle and i never had any problems. Since it is alluminum they won't rust and will be easy to bend. I really don't see anything wrong with it at all. Stainless will look nicer but you pay for that.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 04-17-2008, 02:00 PM   #8
jlaird
jlaird's Avatar
Re: air valves ???
Josh
Where did you get the aluminum line?
Were the fittings also aluminum? What type are they and where did they come from?
Old 04-17-2008, 03:45 PM   #9
1966ponyguy
1966ponyguy's Avatar
Re: air valves ???
McMaster Carr has some coils of aluminum tubing rated at 400 psi. cleaned up nice (almost could pass for polished with a very little work and some fine sandpaper. Think a 25' roll was like $30. I used 1/2" but they have lots of sizes. I'm sure you can probably find it local as well.
1966ponyguy is offline   Reply With Quote
Old 04-18-2008, 12:44 AM   #10
jlaird
jlaird's Avatar
Re: air valves ???
what fittings did you use?
Old 04-18-2008, 02:00 AM   #11
abadsvt
abadsvt's Avatar
Re: air valves ???
I used some compression fittings from Home Depot. This was about 3+ years. I am not sure if there is better things to use but it worked fine for me. The only thing i had a problem was making sure the ferrel sat properly. Just took a little longer to get all set up. I was only using 1/4" lines so fittings were easy to find. Good luck
Josh
(Project truck)
Thread Tools
Display Modes
