Old 04-30-2008, 04:49 PM   #1
AirborneC10
Wiring/Alternator Question
I had to replace my alternator yesterday (unfortunately I got the wrong one, so I have to replace it again today) and I made a stupid stupid mistake.
Red Wire I know where it goes.
Black wire, I know where it goes.
I have two other wires that plug in to the back. One is yellow, one is bluish-green. I would suspect that they aren't the original colors, but can't hurt to ask.
I -thought- I wrote down "Yellow on top, Green on bottom" but then it was raining and the paper fell in the mud and I stepped on it, so I can't read it.
I may have wrote down "Green on top, Yellow on bottom"
So now I am utterly confused. And by "top" I mean when the alternator is mounted correctly.
So any help? Suggestions? How do I know if they are in correctly? or wrongly?
1970 C-10 with 350 crate motor.
AirborneC10 is offline   Reply With Quote
Old 04-30-2008, 10:24 PM   #2
AirborneC10
Re: Wiring/Alternator Question
Bump
Old 05-01-2008, 01:18 AM   #3
john
member #16
john's Avatar
Maybe this will help if the colors have been changed.
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
john is offline   Reply With Quote
Old 05-02-2008, 12:33 AM   #4
AirborneC10
Thanks for the link - thought it would help, but not really.
Can anyone tell me what the two ports on the back of the alternator are for? (the two tabbed slots for the two wires I mean).
I switched the wires and nothing -seems- to be affected, but that can't be right, right?
The alternator reads R and F for each of the places for the two wires...
Old 05-02-2008, 01:37 AM   #5
john
member #16
john's Avatar
On the F (field) wire you want 12v with the ign sw on. dark blue
On your voltage reg the brown wire will have 12v with ign on
Red wire hot all the time. The field wire regulates how much the alternator puts out. If you put a 12v jumper wire from your battery to the field terminal on the alt. it should go to full output. (for test purposes) Not sure about the R post.
Thread Tools
Display Modes
