Old 05-04-2008, 03:34 AM   #1
RaceAGMC
RaceAGMC's Avatar
Door Lock problems...HELP!
When i bought my truck it did not come with door keys. I ordered a new set of locks, but now when i installed them i can not get the door to lock when i close it, or lock it with the key when it's closed. I made sure i installed the lock and mechanism back the same way it came out. Please help me get this thing locking correctly.
RaceAGMC is offline   Reply With Quote
Old 05-04-2008, 03:42 AM   #2
2nd_wnd
2nd_wnd's Avatar
Re: Door Lock porblems...HELP!
I had the same issue with trying to lock one of my doors. I found that if i push in on the door it locks with ease. I'm guessing its just an alignment issue but with getting ready to tear them off i decided to leave it.
I never lock her anyway, if the theives want something out of it, take it, just don't break the glass.
72 LWB
2nd_wnd is offline   Reply With Quote
Old 05-04-2008, 03:59 AM   #3
RaceAGMC
RaceAGMC's Avatar
Well i want to lock mine, i live in a not so good part of town, and my nicer truck is in the garage.
Old 05-04-2008, 04:50 AM   #4
cdowns
cdowns's Avatar
like he said try aligning it a bit better so it will lock with the key
;;ocking with the key is the only way to lock these doors from the outside they dont have the option of pushing the button down and closing the door to lock it when you get out
Old 05-04-2008, 02:15 PM   #5
GMCPaul
Re: Door Lock problems...HELP!
If everything is lubed properly and the locking mechanism on door latch isn't froze up and you can lock and unlock it with door open then it sounds as though your door striker plate is either to far in or out, if you try pushing or pulling on door while trying to turn the key it should lock. Then after you determine whether you needed to push in on door ( striker plate needs moved outward, or you had to pull on door to lock striker plate needs moved inward then you can adjust the strriker plate )
2nd_wnd your striker plate needs moved outward some.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 05-04-2008, 02:16 PM   #6
70GMCer
70GMCer's Avatar
Had the same problem on the drivers side. I tried adjusting the striker without any luck. I ended up buying a repop door lock assembly. Fixed the problem. Now I can lock the doors.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-04-2008, 11:34 PM   #7
RaceAGMC
RaceAGMC's Avatar
thanks guys, i will have time tomorrow to fiddle with it some more and see if i can get it going in the right direction.
Old 05-05-2008, 02:44 AM   #8
whatnow123
whatnow123's Avatar
I just had the same problem, bend the rod from the handle to door latch so it's a little longer and has a little tension. There is a little lever on the striker where the door latch "locking deal" slides through and if the rod is "to short", it won't let that locking arm slide through... if that makes any sense.
It worked for me.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 05-05-2008, 05:56 AM   #9
RaceAGMC
RaceAGMC's Avatar
It doesn't make much sense right now when i'm not looking at it, i'm gonna mess with it tomorrow and see if i can get it goin.
Old 05-13-2008, 12:15 AM   #10
RaceAGMC
RaceAGMC's Avatar
I ended up adjusting the striker plates on both sides, i got the passenger side where i don't have to push or pull on the door to lock it. But the drivers door is giving me trouble, it doesn't matter where i adjust the striker plate to, i still have to push on the door to lock it, so what gives?
Old 05-13-2008, 12:47 AM   #11
john
member #16
john's Avatar
I had the same prob. There was excessive wear and the wheel would turn far enough that the lock would not engage. Fixed with new latch.
john is offline   Reply With Quote
Old 05-13-2008, 11:23 PM   #12
tjvending
tjvending's Avatar
I had the same kind of problems with the doors not locking. After playing around with it I found that if I had the doors open and turn the key to lock them and hold it locked, then shut them it would lock. It worked for me.
TJ
tjvending is offline   Reply With Quote
Old 05-13-2008, 11:40 PM   #13
El Jay
Gone to greener pastures
Sometimes the driver's door on my '69 won't lock.
I open it & then shut it hard (as opposed to "slamming" it) and then it locks fine. It's kind of an intermittent thing on mine.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-14-2008, 12:48 AM   #14
RaceAGMC
RaceAGMC's Avatar
I already ordered new locks cause i didn't have keys to the existing ones, and i plan on keepin the truck for quite some time, maybe i'll just buy new strikers and lock mechanism. They are cheap enough and it can't hurt.
Old 05-14-2008, 01:38 AM   #15
70GMCer
70GMCer's Avatar
you can't go wrong with changing the lock mechs. After all, they are 40 years old. The drivers side is used more than the pass.
1997 GMC Sierra Ext
1965 Mustang
Thread Tools
Display Modes
