Old 05-07-2008, 09:27 PM   #1
76PasoGMC
DMV Prodecure for Replacing Cab
OK guy's I have a quick question on the DMV procedure for swapping cabs
This is HYPOTHETICAL!!
Ok I have a 76 K15 it is a CA vehicle with a FEDERAL SMOG. Its the Heavy Half so it goes with only the FEDERAL requirements.
I have a 76 C20 Cab from a CA vehicle with CALIFORNIA emissions. It has all the smog crud.
My question is if someone were to put the C20 cab on the K15 frame, what would happen to its emissions requirements?? I have to make sure I don't lose the Federal SMOG. I only need a PCV and the original Air Cleaner. I do not want to have to use all the smog crud. Any ideas!!
Anyone care to weigh in??
Thanks Tony
76PasoGMC is offline   Reply With Quote
Old 05-07-2008, 10:37 PM   #2
rfmaster
rfmaster's Avatar
Re: DMV Prodecure for Replacing Cab
Thanks Tony
Try to locate VIN on the frame of your truck. If you have vin on the frame you can swap cabs without major worries since a cab is not a 'major' structural member. I am not advising (advocating) moving vin plates, but it is commonly done due to rust repair on the door post etc. Also, fiberglass cabs are available, so retaining original VIN plate is obligatory.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 05-07-2008, 10:45 PM   #3
AceX
>130dB Moderator
AceX's Avatar
Just swap the VIN plates.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-07-2008, 10:53 PM   #4
76PasoGMC
Well thats interesting because I do have some cab repairs with the new cab........I may just have to do a little more cutting welding and grinding.
Thread Tools
Display Modes
