Old 05-10-2008, 05:14 AM   #1
ap2002
what size tire for 16x10wheel?
im wanting to go with some 16x10 wheel in the rear but cant find a good tire size for for? what tire size would look good in the back, I want atleast a 275 or bigger (305)? but I cant seem to find anything..
edit: also what is a good size tire for a 16x8 in the front?
thanks for the help...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 05-10-2008, 05:28 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: what size tire for 16x10wheel?
How about a 295/50/15? You'll have a section width of at least a foot!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-10-2008, 05:31 AM   #3
ap2002
i thought of that but then i checked and they dont have them in a 16" tire!
Old 05-10-2008, 05:33 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Look here at BFG's: http://www.tirerack.com/tires/Spec.j...3D295SR6RADTA2
Jim
Old 05-10-2008, 05:43 AM   #5
ap2002
thanks 70c10!
I like how the 275/60/15 looks on a 15x10 wheel, so do you think the 285/60/16 will look just as good with a 16x10 wheel? is anyone running this 16"setup?
Old 05-10-2008, 11:55 AM   #6
ap2002
anyone else?
Old 05-11-2008, 08:52 AM   #7
19GMC63
19GMC63's Avatar
I'll be watching this thread... I'm curious to know what size tire to use on a 16x8 wheel too.
19GMC63 is offline   Reply With Quote
Old 05-11-2008, 06:07 PM   #8
rodstored-72
chevy truck fan
rodstored-72's Avatar
i have 16x8.5 centerlines & when i got my truck back on the road i went to discount to get my tires & about all i could find in the 16" size were my 255/60/16 it is not what i wanted but the guys there said that with the new size of wheels that alot of the tire people are not making a 16" tire. atleast performance tire. i could get a truck tire for the 16" wheel & some for the 16.5 wheel. they still make alot for the 15" wheel & then ofcourse the hot wheel sizes like 18" and above. i was disappointed, but the 255 size is not bad in the back but it is a little big for the front. i decide on them & to just save up & get my 18" wheels & tires when i can....
good luck!
rodstored-72 is offline   Reply With Quote
Old 05-12-2008, 02:40 AM   #9
ap2002
good luck!
got any pics of your truck?
Old 05-12-2008, 03:49 AM   #10
Adctfull1
here is what i went with, 16x8 up front & 16x10 in rear. Bfg radial T/A's 225-60-16, & 295-50-16. At the time they were cool-e-nuff ( 6yrs ago ). wish i had the wallet for some 18s or 20s
Adctfull1 is offline   Reply With Quote
Old 05-12-2008, 07:19 PM   #11
ap2002
I think that is what im going with 16x8 in the front and 16x10 in the rear do you happen to knowthe backspacing on those?
Old 05-12-2008, 10:04 PM   #12
Adctfull1
i believe its 5in., i'll have to measure it to be sure. Are u running the trailing arm or leaf spring setup? & is this for ur bbc 68?
Old 05-13-2008, 05:13 PM   #13
ap2002
yes this is for the 68',,
im going with a 16x10 w/295-50-16 and 15x8 275-60-15 in the front...
this is the wheel im going with...
[IMG][/IMG]
Old 05-13-2008, 10:18 PM   #14
rodstored-72
chevy truck fan
ap2002,
have you checked those tire sizes out at the tire shop? i had planned out my tire sizes as well & when i went there they did not offer those tire sizes anymore or i would have to special order them directly from the manufact. $$$$ big time. just my 0.02 cents worth. i will try to get a few pics of my truck tonight. i always say that then i look at it & find all the reasons why i haven't yet.... but i will try this time!
thanks!!
Old 05-13-2008, 10:25 PM   #15
HoupPhotography
I would try looking at Coker HERE
OR
Diamond back tire HERE
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-13-2008, 10:46 PM   #16
ap2002
ap2002,
thanks!!
yes, i went to discount tire today and they had them in stock ... they wanted $150/tire... and said they would price match it...
i just found it at tirerack also..
http://www.tirerack.com/tires/Compar...t=All&x=46&y=3
Old 05-15-2008, 02:09 AM   #17
Adctfull1
i paid $110 each 6yrs ago. what rear susp. do u have? the only reason i ask is, cuz i have trailing arm & with the old rotted out bushings the tires would rub.
Old 05-15-2008, 02:31 AM   #18
ap2002
TRAILING ARMS... how bad did rub and how did you fix it??
thanks for all the info..
Old 05-15-2008, 06:34 AM   #19
Adctfull1
Cool Re: what size tire for 16x10wheel?
they would only rub under hard cornering. cuz the bushings in the trac. bar were totally gone. i cured the problem by building my own adjustable hardbar with spherical ends
Thread Tools
Display Modes
