05-11-2008, 09:22 PM | #1 |
70 Chevy Leftovers
All you see for $250 or bed $150,w/gate or $150w/o gate,trans. $75,6 banger complete $75. Ask if you're interested in anything else. NO SHIPPING on the big stuff. Please respond to post.
05-11-2008, 09:23 PM | #2 |
Re: 70 Chevy Leftovers
More pics.
05-11-2008, 09:24 PM | #3 |
Last set.
05-11-2008, 10:21 PM | #5 |
Long bed.
05-12-2008, 03:04 AM | #6 |
I am interested in the carb, air cleaner assembly, heater tube, support rod which holds the air filter on the passemger side of engine. Also the carb spacer and valve cover. please a total package price shippe to Fort Worth TX 76133 if you decide to sell the engine pieces.
...try'n to be a little! This is a great site. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
05-12-2008, 03:06 AM | #7 |
If in case you decide to sell teh engine pieces please send me a P.M., In case I lose track of this post, Thanks!
05-12-2008, 08:28 PM | #8 |
Pm sent.
05-12-2008, 10:15 PM | #9 |
Pics for N2GMTrux. The rust is only surface. All the gook in the 4th pic is the melted plastic.
05-12-2008, 10:16 PM | #10 |
One more.
05-12-2008, 10:26 PM | #11 |
Retired Air Force Veteran
Tim.
If your selling the fan in the 11th picture can you get me price shipped to 33024. Also, can you measure the fan from blade to blade. My shroud is 20" - the fan I have is 20". Don't want to run it with out a shroud and I don't want to run a flex fan. Thanks, Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
05-12-2008, 10:29 PM | #12 |
$25 shipped w/bolts.
05-13-2008, 02:56 AM | #13 |
Tim, What's the size of the fan - blade to blade? Thanks, Harry
05-13-2008, 03:32 AM | #14 |
17 1/2" across.
05-13-2008, 03:37 AM | #15 |
Thanks, PM Sent
05-13-2008, 04:13 AM | #16 |
Can the gunk in the third and fourth pics be sandblasted out of there and made to look original again? Is the entire oil assembly of the filter also damaged from the fire. The black gunk stuff is cooked motor oil,,,,, correct, in the third photo. And when you say burnt plastic where did the plastic come from! On the valve cover did the light fire just caused surface rust or is it warpped... Thanks
05-13-2008, 04:42 AM | #17 |
The plastic I'm talking about is part of the oil bath in #3. I don't know if you can buy that piece. All the rust can be blasted away, but I will get them off tomorrow and make absolutely sure.
05-13-2008, 05:41 AM | #18 |
Ok, I will wait for your next reply. Thank You
05-13-2008, 09:55 AM | #19 |
are you close to conyers
05-13-2008, 05:40 PM | #20 |
I'm in Conyers.
05-13-2008, 05:46 PM | #21 |
Hey Tim,
Forgot to ask. Will the Fan work on a 350? Thanks, Harry
05-14-2008, 12:53 AM | #22 |
More pics for N2GMTrux. The only thing that may have a small pit or 2 would be the valve cover after blasting. I tried to show the worst place on the valve cover.
05-14-2008, 12:53 AM | #23 |
One more.
05-14-2008, 03:32 AM | #24 |
Ok, I thought about it and will pass on valve cover and carb.....
BUT, will take the AIR FILTER assembly with all hardware (meaning the brace on passenger side of the engine with bolts and the treaded wing nut which holds the air filter assembly). The heater tube assembly, the carb spacer (which goes between the carb and air filter) and the threaded rods and wing nuts which are on the carb. Price plus shipping to Ft Worth, TX 76133
05-14-2008, 04:23 AM | #25 |
i pass by your place everyday ive been meaning to stop and talk to you ill send you a pm
Thread Tools | |
Display Modes | |
