Old 05-17-2008, 06:59 PM   #1
BHall
New Front End
I have a 1981 SWB and am wanting to put a front end kit on. I dont wont a drop or anything I just want a new front end with tie rods bushing etc. Who is the best company with all the parts needed in one purchase. Any help would be appreciated. Thanks.
BHall is offline   Reply With Quote
Old 05-17-2008, 08:45 PM   #2
Shane
Shane's Avatar
Re: New Front End
your local NAPA would be a good place ... support your local business where you can.
Shane is offline   Reply With Quote
Old 05-18-2008, 06:14 AM   #3
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: New Front End
I'm doing the same on my stock height and suspension 79 Sierra Grande, as far as I'm concerned Moog makes the best chassis parts for the money. I don’t know if there are better high performance parts but if you’re going stock I would use Moog. Here’s my list, if it helps.
Idler arm Moog K6096T
Pitman Arm Moog K6143
Pitman seal kit skf 12392
Gear Box cardone 277512
Stabilizer moog ssd10
Tie Rod inner Moog ES409LT
tie rod outer Moog ES409RT
tie rod sleeve Moog ES2004S
Lower Ball Joint Moog K6117T
Up Ball Joint Moog K6136
Shock front Rancho RS5120
Shock Rear Rancho RS5118
Bushing kit Energy susp 3-18109
I found all of this on Amazon a lot cheaper then my local Checkers, and free shipping on most of it. Also check out http://www.energysuspensionparts.com...s.asp?cat=2330 for your bushings. The master kit covers just about everything including control arm bushings and body mounts.
79gmcsierragrande is offline   Reply With Quote
Old 05-18-2008, 07:28 AM   #4
SBTork
Garage wrench
SBTork's Avatar
Re: New Front End
p-s-t has a good front end kit to do the whole job
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Thread Tools
Display Modes
