Old 05-18-2008, 12:42 PM   #1
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Installing a C-notch question?
Besides using a plasma cutter what is the best tool to use to cut the frame when installing a c-notch? I plan on lowering the rearend 5" or 6" so I figured that I would notch the frame.
jgrisafi is offline   Reply With Quote
Old 05-18-2008, 12:52 PM   #2
oldspowered67C10
Re: Installing a C-notch question?
A torch works pretty well but you have to clean up the cuts w/ a grinder. Or you can use a cut-off wheel and a grinder although that limits you to straight cuts.
oldspowered67C10 is offline   Reply With Quote
Old 05-18-2008, 01:02 PM   #3
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Dont forget the best tool of them all,, a SawZaw
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 05-19-2008, 06:32 AM   #4
72LoBurb
Yup, I'm comp-useless
I used an angle grinder with a cut-off wheel, but I used a LARGE drill bit to do the corners prior to cutting the frame, then cut between the holes. The rounded corners are less likely to crack
1972 Chev Suburban(ongoing driveable project)
2010 Harley Wide Glide
1996 Subaru Outback(daily beater)
!992 T-Bird Super Coupe(yet, another project)
1995 GMC Suburban(will be for sale, soon)
1995 Dodge 3500 Club Cab(Cummins 12V)
2001 Freightliner(Cummins Powered Money Maker)
72LoBurb is offline   Reply With Quote
Thread Tools
Display Modes
