Old 05-20-2008, 10:55 AM   #1
johnboyon20s
2 link??
ok im new here but ive owned a few bagged rides so i know all the no, whoa,and ohs of 2links,but every truck ive had has had a basic 2 link with panhard and rode great to me, daily driven,
my current project is 82-c10, as far as what i want out of this truck is, i wanna ba able to drive it anywhere, go to the drag race track make a few passes, maybe even take it to one of those air ride challenge courses and have some fun, im undecided on drivetrain, considering bigblock, but small block is prolly what i will have in it. basically i guess wat im sayin is i want it to hook up and take corners too........
now my idea for the rear is a 2link, and i dont have any pics its just in my head but if u could picture this> long bars something similiar to the 67-72 2-link setup(maybe a inch or so longer then that) and the bars are gonna be parallel to the frame rails with the bag between the bars and frame rail.
im gonna be running a watts link and im thinking of using these bushings http://*****************/SuperPivotBarEnd.php, im thinking my pinion angle will be set at my ride height
my question is for any of u suspension guru out there, do u think my truck would take corners with the super pivot bushings on a 2-link and watts link?
would this super pivot 2-link be worth trying?would this be a waste of time? should i just do another setup?
johnboyon20s is offline   Reply With Quote
Old 05-20-2008, 04:11 PM   #2
bedsled71
bedsled71's Avatar
Re: 2link??
when i built my 2-link i also thought about using those... seems like it would work
bedsled71 is offline   Reply With Quote
Old 05-20-2008, 05:22 PM   #3
SCOTI
SCOTI's Avatar
Re: 2link??
Why not use the GM truck 2-link set-up? The truck arms are proven so you know they'll get the job done. Add the truck arm crossemember, some spec made frame brackets for the bags & a Watt's. You should be able to achieve your goal of decent, low ride w/cornering ability.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2008, 07:39 PM   #4
HotRodYJ
HotRodYJ's Avatar
Re: 2link??
NASCAR use the truck 2 link beams and a trac bar and they seem to handle just fine.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 05-20-2008, 07:56 PM   #5
SCOTI
SCOTI's Avatar
Re: 2link??
I agree, but the argument is flawed. NASCAR uses whatever is mandated, not what's best. We know the Watts-link limits side shift to zero while a PHB allows slight shift through the range of suspension travel which is important to guys stuffing their wheelwells full of expensive rubber.
I know truck arms work very well for me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2008, 08:09 PM   #6
HotRodYJ
HotRodYJ's Avatar
Re: 2link??
My argument was not necessarily in favor of a trac bar, just that a 2 link system can work very well. Sorry for the confusion, we are in agreement.
Old 05-20-2008, 09:00 PM   #7
SCOTI
SCOTI's Avatar
Re: 2link??
It's one of those things..... Once you mention "because NASCAR use's it, it must be good", you might get pounced by someone who dislikes truck arms on race cars.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2008, 10:02 PM   #8
jimmydean
jimmydean's Avatar
Re: 2link??
Originally Posted by SCOTI View Post
It's one of those things..... Once you mention "because NASCAR use's it, it must be good"...
So you are saying I shouldn't use Tide?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-20-2008, 10:09 PM   #9
SCOTI
SCOTI's Avatar
Re: 2link??
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2008, 10:23 PM   #10
grnddwn
belly dragger
grnddwn's Avatar
Re: 2link??
I don't know about tide but the the car with Erectile help logo has me concerned doesn't it get in the way of the steering if the driver's using it.
Anyway put me down as another truck arm fan.
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Thread Tools
Display Modes
