Old 05-24-2008, 04:25 PM   #1
gunshotwoundshurt
gunshotwoundshurt's Avatar
Heater Core / Install
I know that since i live in SOCAL i dont really need a heater (dam sure need an A/C ). But during my recent motor install i think i cracked one of the welds on the outlet lines from the heater core when i was replacing both hoses. Not much of a leak but enough for it to bother me.
Question : How much of a pain in the butt is it to replace? Any suggestions on making it easier to replace without me having to learn the hard way?
Any and all help is greatly appreciated.
Semper Fi
Mel
74 GMC SWB 350/350 Combo
2005 GTO LS2
2006 Husqvarna SM610
2006 Suzuki GSXR1000
2007 KTM 560 SMR
gunshotwoundshurt is offline   Reply With Quote
Old 05-24-2008, 04:35 PM   #2
mhicks
mhicks's Avatar
Re: Heater Core / Install
If you could get some sandpaper on the crack maybe try some JB Weld......
mhicks is offline   Reply With Quote
Old 05-24-2008, 06:44 PM   #3
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
I just did mine on my '77. Not to bad to deal with. Non AC
1. drained a little fluid off the coolant to be below the fittings.
2. removed the hoses
3. removed the 3 nuts on the heater box cover (inside the engine compartment)
4. took off glove box door
5. removed the floor deflector 1 screw
6. unhooked the control cables
7. unhooked the defroster vent ducting from the box. 1 screw
8. removed 1 or 2 bolts from under the dash holding the heater core box to the fire wall and removed
9. removed core from box & replaced with new core after cleaning and painting
10 reverse order to install
I'm slow, it took me most of the day most of it cleaning any painting waiting for the paint to dry.
Good Luck & God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 05-24-2008, 08:46 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
My heater core leaks so I just disconnected it 15 yrs ago and have been without a heater since
Malo83 is offline   Reply With Quote
Old 05-24-2008, 09:40 PM   #5
mexgrhd68
mexgrhd68's Avatar
Smile Re: Heater Core / Install
HEY MALO, how do you do it when driving in the cold weather? load up on the blankets? gets pretty cold around here, im in Visalia,neighbor.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 05-24-2008, 11:05 PM   #6
gunshotwoundshurt
Terry: Thanks for the info. Looks like I'll pull it apart tomorrow.
2005 GTO LS2
2007 KTM 560 SMR
Old 05-26-2008, 08:02 AM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Small world huh , yeah it can get cold here in the valley especially on those cold foggy days but as long as I have some nice warm gloves it's no problem
Old 05-26-2008, 11:09 PM   #8
Square84
I don't think these pills work
Square84's Avatar
that one bolt on the bottom is a pain had to use 2 extensions an a uni- wiggle and a couple of bad words next time ill pull the inner fender out.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Thread Tools
Display Modes
