Old 06-04-2008, 07:06 PM   #1
1970pelle
1970pelle's Avatar
Oil pressure switch. Pitch it ?
While I still have my 86 C10 5.0L apart.There are two oil thingys mounted at the back of the block,dist. area.One is send unit other is a oil press. switch?.Thats shuts the engine down at low oil PSI? What is involved in removing it.Anything.I have removed all ESC,smog,change dist wiring.So is it save to just unplug and remove?
1970pelle is offline   Reply With Quote
Old 06-04-2008, 10:04 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: Oil pressure switch.Pitch it ?
Pic?
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-05-2008, 07:55 AM   #3
beaterC10
If you have factory gauges you should have a sender for the oil gauge and a switch that is used to control the electric choke. There is nothing that will shut the engine down for low oil pressure.
beaterC10 is offline   Reply With Quote
Old 06-05-2008, 08:51 AM   #4
friscocrownie
Where is the oil pressure sending unit on a 305?
friscocrownie is offline   Reply With Quote
Old 06-05-2008, 10:05 AM   #5
Jonboy
Slots go on anything!
It should be right behind the distributor, a little towards the driver's side. If you have a gauge, it will look like a bell, a sender for a light will be smaller and thinner. In 87-up (and possibly a little earlier) it was moved to the port right above the oil filter. The FI trucks integrated the fuel pump switch and oil pressure sender into one unit.
Old 10-26-2008, 07:20 PM   #6
friscocrownie
Re: Oil pressure switch. Pitch it ?
I tried to find the oil pressure switch tonight and didn't have any luck, is this something I should be able to see top side? I have the replacement switch already to compare against, just didn't see anything that looked similar
Old 10-26-2008, 07:24 PM   #7
S10Fan
Old Heap Driver
Fuel Injection/Fuel Pump could be tied into that switch.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 10-27-2008, 12:35 AM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Thats what I was wondering. There is no switch I know of either that shuts the motor down when it has low oil pressure. Do you have any pics of what you are talking about?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-27-2008, 01:34 PM   #9
nico
nico's Avatar
On my 84, the gauge is connected to the plug next to the distributor. The choke light is connected to the switch just above the filter. If you unhook the wire next to the distributor, it will just peg the gauge at 60 psi. If you unhook from the lower switch, the choke light will come on. I was told its a failsafe that even if you aren't watching the gauge, zero pressure will turn on the red choke warning light.
nico is offline   Reply With Quote
Thread Tools
Display Modes
