Alright Alright Alright
distributor installation trouble
i am reinstalling the distibutor in my truck and i cant seem to get the timing mark to reach the timing tab. i have done this a million times on this exact truck (the timing chain cover is correct). i have taken it out and set it to TDC 0 and reinstalled it and everytime is the same. i can get the engine running and when i put tht timing light on it, it is under the water pump each time reguardless of how i turn the distributor. the vacuum advance is pluged and everything seems to be in order. its driveable, but not tuned at all. what can i do?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: distributor installation trouble
I would say its idling to fast and your mechanical advance is kicking in. Set your idle lower and see if that makes a difference.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
72 Chevelle Club
Possible that the outer ring on your balancer has slipped . If so new balancer time . my 2 cents worth
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
You may be a tooth of with the distributor which wouldn't allow enough room to turn the housing (interference between vacuum advance and manifold).
Also, you do have the vacuum hose disconnected and plugged? Bob 68327 posted when i was writing and that is another thing to check. make sure the #1 is exactly at top dead center and see if the mark lines up at 0. Last edited by mr48chev; 06-11-2008 at 11:54 PM. |
each time i reinstalled the distributor, i put it in a new position (its in a position now where i can spin it all the way around). i dont think that the balancer hasnt slipped since i took the distributor out.
Hollister Road Co.
maybe you knocked a weight springs off under the rotor and it goes to full advance way to soon
Is your timing light on the #1 plug?
HTH.....don t. ..... |
Active Member
![]() Join Date: Jul 2007
The way I always check mine...
I disconect the distributor to coil wire and take the sparkplug out of the #1 piston (for easier turning, I sometimes take them all out). Then with help or with a breaker bar on the crankshaft pulley I turn the engine until I start to feel compression on my finger. Some people plug the hole with a rag. I just use my finger. When I start to feel compression, I know that I'm on the compression stroke and I insert a long thin screwdriver and feel the piston until it reaches TDC. Then I look at the timing mark - should also be TDC- and the distributor to make sure everything is lined up correctly. If it is, then there's something else moving that is causing the problem. Good luck.. |
#9 | |
If I am understanding this right you said the vacuum advance is plugged. in? Might be me just not understanding you correctly. It would explain your trouble if it is plugged into the distributor. I should be unplugged while checking timing.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
Does your timing light have a dial-back knob? Could be that the knob is just mis-adjusted....
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone ![]() |
i have the advance hose plugged and off the distributor. and yes, the timing light is on the number 1 cylinder. the timing light doesnt have the dial on the back. its just a basic one.
Active Member
[QUOTE=crm318;2762755]i have the advance hose plugged and off the distributor.....QUOTE]
Just to make sure--- once more ![]() The plug should be on the vacuum line from the carb that goes to the distributor. I'm sure it's what you mean, but some new guys may think that you need to plug the hose coming from the vacuum advance. ![]() Anyway, if all the checks indicate that that your distributor, balancer, chain and sprockets are all lined up and in good conditon and your timing mark is way off when it runs, then there's something loose or worn in the distributor.. Let us know what you find... Last edited by 68gmsee; 06-12-2008 at 04:04 PM. |
#13 |
Parts and more parts
What did you do to the distributor? Why was it pulled out of the engine? That might explain the problem you are experieincing. Was the timing right before you started in the first place??????
Start at ground zero again and go about this in a deliberate way 1. pull dizzy once again 2. pull plugs and verify that at TDC on #1 cylinder 3. verify dizzy is not hanging up on the advance mechanism inside it and weights are moving freely. 4. re-install dizzy at #1 post indication 5. start engine and set timing (With the vacuum hose disconnected--I plug mine on the carb centerbolt) 6. does timing stay in one spot or does it seem to move around as the engine runs? |
#14 |
Did you check the idle speed and your mechanical advance springs as dwcsr said?
Jeff
#15 |
the hose is plugged at the carb, not the advance. i have done this a few times. this is the only time this has happend. i have a new distributor that i have been swapping in between vehicles (every few months). i put the old distributor back on. i will check it thouroughly and and get back to yall.
#16 |
![]() Join Date: Sep 2005
make sure your not a plug wire off if your a wire off ont he cap it will do the same thing
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#17 |
Active Member
Yep, I figured you had.
![]() I read a post in another forum where a guy said he had the vacuum advance hose plugged and still couldn't adjust the timing properly. He had plugged the hose on the vacuum advance side. |
#18 |
This is a common wording issue, regarding the differnce between "plugged" and "plugged-in"
#19 |
im away from home for a day or two so i will let yall know know when i get back to it. the thing is, reguardless of where i turn the distributor, it will not run correctly. i think that the installation is not it and maybe the distributor itself.
#20 |
well i dropped in a newish distributor and im having the same exact problems. everything in the new dist. is free moving and fully functional. i even moved the plug wires around (in correct order still). i cant figure it out for the life of me.
#21 |
Senior Moment
![]() Join Date: Mar 2002
Just out of left field , did this thing back fire at any time while trying it the 1st time??
If so maybe it jumped time.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#22 |
Junior Member
![]() Join Date: Mar 2007
explain "jumped time"????
frontstreetcycle on Instagram |
#23 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Jumped timing means that you have slack in the timing chain and now the 2 marks on the timing gears do not line up as they are supposed to. That could happen from worn gears and/or timing chain.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#24 |
And if that does happen, the cam timing is off, retarded as much as the ignition timing. Generally when this happens, it will not start. You wouldn't really want it to anyway. It is time for major surgery.
Thread Tools | |
Display Modes | |
