![]() Join Date: Sep 2007
My 67 has the positive junction block that mounts to the passenger fender (+ battery to block) from here the power is diributed. My question is, are any of you guys running a better power distribution strip or block? I also have tied in the 16 inch fan, (got rid of the fan that hooks up the waterpump) juiced up headlight system, (the relay kit with HID lights) and soon to have an amp hookup for the deck but the amp will be wired directly to the battery
1967custom |
Gone to greener pastures
![]() Join Date: May 2007
Re: battery strip options
If you're talking about barrier strips, I believe Radio Shack has them.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
O Rielly's sells a 30 Amp mini panel that you connect to the pos pig tail. $10 I think. Use that and replace the lead of single point next to your battery. It holds 6 - max 30 amp fuses gives you an option.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Aug 2004
I used the 5 lug voltage block out of a 90's TBI truck. They're easy to find at the junkyard and cheap. Just look on the pass firewall under the plastic cover that has all the wires running out from under it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
I`ll look up o reilly`s now sammy thanks. lets see if they have what Im looking for
1967custom |
Im headed to the used toy store this afternoon as a matter of fact, I`ll keep an eye out for one of these, thanks for the idea
1967custom |
Back in the sticks
If you go to a boat supply place, they have power strips you can put in for this. Thats what I put on the 71 so I could run all the TPI, fans and all that crap off of if I needed it. Cheap and non-conductive too.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Thread Tools | |
Display Modes | |
