Keep Your Nose Clean
Can a bent wheel "really" be repaired?
I was considering buying a set of used wheels, but one of them is bent. Have any of you ever had a bent wheel repaired? Was the repair as good as you expected or did it still have issues after the repair? Thanks. MisterE
Re: Can a bent wheel "really" be repaired?
I've had one on an audi repaired. It looked just like new when they were finished, but it wasn't as bent as that one. You might want to watch out for hairline cracks with that one.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Official Site Guitar Shredder
Yes, they can be fixed sometimes.as i think aluminum is the Key in fixing them.........i have had my front wheels on sweet pea fixed three or for times.....by Mr Wheels of Indy.......i USED to run a very low profile and the Indy chuck holes took there toll on them ......Anyways , i would look in the yellow pages for wheel repair.....Or stop by a local collision shop and see who they recommend ,or who they use.....I think Trans wheel....is who we use at work....and they SHOULD be like a nationwide carrier.........Also if you are getting a smokin deal on them.....You may just have to buy ONE new one instead on all four......depending on the deal......
Retired Air Force Veteran
![]() Join Date: Aug 2007
I have seen wheels worst than that repaired, but it is not cheap. I live in the Ft Lauderdale area and there are a few shops that repair wheels, These guys get top dollar. Unless the wheel was no longer available, I'd consider just replacing it. That my .02 on fixing a wheel.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Chevy nut
I dont think I would trust it after it was fixed. I think I would just get another wheel.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
![]() ![]() Join Date: Dec 1999
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
If that's one piece billet, which it looks like it is, I wouldn't go the repair route, just me opinion.
R.I.P. Scott Kalitta
Gone to greener pastures
![]() Join Date: May 2007
I'm certainly no expert on wheels.
But, to me, fixing that wheel and then using it would be just scary to me. I'd replace it. I always prefer to err on the "safe" side. That's just my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-15-2008 at 05:01 PM. |
![]() Join Date: Aug 2004
We send out aluminum wheels to get repaired at work all the time. I say go for it, the worst the repair place can say is that it's not repairable.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 06-16-2008 at 01:48 PM. |
#11 | |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
so easy a caveman can do it...
![]() Join Date: May 2006
Personally...I wouldn't repair that. I would buy a new one and offer less money for the rest of them.
#13 |
Just last month I had one of the alloy wheels on my Mercedes coupe repaired. I had nailed a guardrail at about 70 mph and it was bent, cracked and had part of the bead area broken off. The repair looks as good as new, but it wasn't cheap. It cost close to $250.00 to have it done, but it was a 25 year old aftermarket, German made wheel that is no longer available. The other 3 wheels on the car are fine, and I wanted to keep the set in tact. Check with some of the local body shops in your area and see who they recomend.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
#14 |
pretty much like most of the guys are saying that wheel can be fixed, wheels get repaied all the time and some of you may be driving around on them right now if your vehicle was ever in a collision and the wheel got screwed most of these insurance companys put what they call a "reman" wheel on there for you. this is a wheel thats either cracked bent busted or dented that is completely reconditioned and then sold as new, most of the companies out there do good work. like someone said check with trans-wheel, or if theres a local keystone automotive supply warehouse in your area (they just merged with LKQ(like kind quality used autopart recyclers) get ahold of them and they are not over the top expensive to repair a wheel.
Thread Tools | |
Display Modes | |
