Old 06-16-2008, 12:00 PM   #1
Luvlegs
Luvlegs's Avatar
One part left over..... ugh!
Put in new inner and outter bearings on the front wheel, then new disk pads ('72) - As I was putting the caliper back on, I had to keep the rear shoe "up" so that it's ears would rest on the through bolts that hold the caliper in place. No biggee once I figured out what needed to be done. When it was all done, I looked down and saw this spring on the ground! I am pretty sure it holds the inner pad in place... Just not sure how. Both my manuals make mention of it but NO PICS! Any help would be greatly appreciated!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-16-2008, 12:19 PM   #2
estig70
estig70's Avatar
Re: One part left over..... ugh!
it snaps on the back of the inboard pad and holds it to the piston.
Eric
estig70 is offline   Reply With Quote
Old 06-16-2008, 12:25 PM   #3
don t. - 72gmc
What estig70 said.
The triangle lookin thing slips inside the caliper piston.
HTH....have fun.....don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 06-16-2008, 12:29 PM   #4
Luvlegs
Luvlegs's Avatar
hmm ok, that makes sense sooo the next question is, is this one bent? It's only about an 1 1/2" across... the pad is alot wider than that... so isn't the inside of the piston - it's about 3 1/2" on the inside....
1972 C10 L6 3OTT
Old 06-16-2008, 08:47 PM   #5
Old Money
that is the anti-rattle clip. if you dont mind an annoying rattle that happens only when driving. you can live with out it. or you can pull the calipers off and remove inner pad snap clipon back side of pad with the spring on the upper half so that it looks like a capital p . and center it in the round hole and reinstall it. old money.
Old Money is offline   Reply With Quote
Old 06-16-2008, 09:30 PM   #6
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Would the 'el Jimador' in the backgraound have anything to do with leftover parts?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-17-2008, 10:57 AM   #7
Luvlegs
Luvlegs's Avatar
The el Jumidor was after I finished up - at least the first bottle was... the second bottle helped take my mind off the clip AND kept me from putting the wheel back on until I got the clip figured out... (it's still not in yet!) Thanks for the info everyone.
1972 C10 L6 3OTT
Old 06-17-2008, 11:03 AM   #8
Luvlegs
Luvlegs's Avatar
double post
1972 C10 L6 3OTT
Old 06-17-2008, 11:16 AM   #9
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
If that one doesn't look right, You could probably get that a new clip in a brake hardware kit from you local parts store. Its a good idea to put new springs and anti rattle stuff on anyway. Would probably run about $10.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 06-17-2008, 11:20 AM   #10
Luvlegs
Luvlegs's Avatar
not sure if it looks right or not - I haven't pulled the other side yet - I was trying to figure out how it could fit across the pad but I guess it mounts in the hole half way across the pad - still would like to see a pic if anyone has a manual or such.... just to help clarify..
1972 C10 L6 3OTT
Old 06-17-2008, 01:37 PM   #11
estig70
estig70's Avatar
I believe that clip pictured is bent, but you are correct as stated above. The "prong" end of the clip goes into the hole in the back of the pad. The "forked" end snaps on the bottom edge of the pad.
Hope this helps.
Eric
Thread Tools
Display Modes
