Old 06-17-2008, 06:23 PM   #1
Old Rust Bucket
Old Rust Bucket's Avatar
what's it going to set me back to fix this??
On my 76 c20 350/turbo 350. I can not go above 30MPH or it gets jerky and tries to stall out. It did this the other day as well but not this bad. I barely made it home. Fuel pump? If so, what would this cost and where's it located. if not a fuel pump then what?
Rice is for cooking, not for burning......
Past and Present vehicles
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old Rust Bucket is offline   Reply With Quote
Old 06-17-2008, 06:41 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: what's it going to set me back to fix this??
fuel filter ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-17-2008, 06:48 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
plugged fuel filter, or bad gas will cause it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-17-2008, 08:01 PM   #4
thebrown83
thebrown83's Avatar
When you shut the truck off is there fuel dripping from under the truck under the front end? Thats what happened when my fuel pump went bad and it also did what you described. If it is not dripping out then it is probably just a filter or something. The fuel pump is located on the passenger side of the engine at the front toward the bottom. If it really is the pump and not just a filter then you can get a new pump for about $40
thebrown83 is offline   Reply With Quote
Old 06-17-2008, 08:17 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i had this problem on an old malibu years back and it was a severely clogged gas filter up at the carb.. funny thing was i had one further down the line that was fine
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-17-2008, 09:54 PM   #6
Old Rust Bucket
So if it is a clogged filter. What's the odds of it driving for the last 4 months no problems and it just suddenly starts 3-4 days ago? Of course I did fill it with gas from a can within the same time frame.......... Or maybe some "gunk" came loose from the bottom of the tank. I also dumped the reccomended amount of gas treatment in it not that long ago that might have knocked something loose.
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old 06-17-2008, 10:00 PM   #7
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Someone else mentioned bad gas, but for the cost of a fuel filter, you can find out. It sounds like most of us have had these symptoms from a clogged filter before. Good luck-
-Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-17-2008, 10:24 PM   #8
Old Rust Bucket
One more thing that might be relevant. Ever since I have the truck if you put the gas to the floor it would stall out.
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old 06-17-2008, 11:13 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Fuel filters are dirt cheap I would try that first. Like stated above when my fuel pump went bad it was leaking gas from up on the passenger side where its located at.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-17-2008, 11:30 PM   #10
f.monroe
f.monroe's Avatar
I drove my 77 long bed to town (30 miles ), went to eat ( 10 miles ) , stopped by a friends shopand commented on how reliable the truck was to one of his customers . Started it up and made it maybe one mile when it died . Started back up and almost did not make it back to his shop . Two dollar fuel filter in the carb totally plugged . replaced it and havent had a single prob since . Change your fuel filter first . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-17-2008, 11:33 PM   #11
89 crew
Did the gas can have any water in it? I have had that problem before from water, add some heat or other alcohol to it and see if that works if the filter doesn't. One more thing, a bad fuel pump doesn't have to drip gas outside the engine. Pull the dipstick and see if it is pumping gas into the oil.
89 crew is offline   Reply With Quote
Old 06-29-2008, 02:07 PM   #12
Big68
I'd have to agree with the general consensus and say that it's probably just a fuel filter.
I took my Silverado into the shop to get an exhaust welded in and it ran fine for the 20 miles there. When I got it back two days later it barely made it home. It would be driving along fine and then just start sputtering and cut out then start running again. But for the $1.99 a fuel filter is, it wouldn't hurt to change it anyway.
1968 GMC, 2wd to 4wd conversion, automatic to manual, 4 in custom lift, 36'' military tires, recent 454 upgrade
1979 Pontiac Firebird, mildly built sb 350, t56 trans
Big68 is offline   Reply With Quote
Old 06-29-2008, 02:13 PM   #13
Old Rust Bucket
already been and done. fuel filter was plugged up tight.
Thanks guys, you were right (again)
'76 C-20
'83 F150
'89 F150
'89 S-10
'97 Sable
Old 06-29-2008, 02:41 PM   #14
piecesparts
Parts and more parts
piecesparts's Avatar
Is the choke closed on the engine and not opening up?
piecesparts is offline   Reply With Quote
Old 06-29-2008, 02:53 PM   #15
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
my 454 east fuels filters, i will collapse them so they dont work.. so it makes it so they seem plugged.. i can go througha couple a year...i had to go to a smaller filter because the one called for, will collapse,,,,
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Thread Tools
Display Modes
