![]() Join Date: Jul 2006
Need advice on where to get pinion seal and crush sleeve.
The local chevy parts house and auto parts stores don't have em.
It's a 1968 12 bolt. |
the boat guy
Re: Need advice on where to get pinion seal and crush sleeve.
use the original crush sleeve and LOCKTITE. the new crush sleeve is a b&tch to try to crush, if you cant live without a new one i would have someone else install it so you can blame them if something goes wrong. just my .02
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
We get ours from Randy's Ring and Pinion. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
If you are simply replacing the pinion seal, you should be fine with your original crush sleeve by marking where the pinion nut is to the yoke and the pinion shaft. Count the number of turns to take off the pinion nut and make sure to put it back on in exactly the same position.
If you need a new crush sleeve, I believe summitracing.com has them. The dealership should have them as well...try another dealership. |
NEVER re-use a crush sleeve !yes , its a pain to crush it ,and you only get the one chance , go too far and its off to try another one .its needs to be done right , there is important bearing preload . 12 bolt uses its own , napa has them in their balkamp help line as the normal "help" section in other stores . if not summit and jegs both have them in richmond and ra-tech , and course there is randy's ring and pinion
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
http://67-72chevytrucks.com/vboard/s....php?p=2399804 and http://cgi.ebay.com/ebaymotors/Ratec...mdZViewItemQQ_
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car Last edited by 66skylarkpost; 06-19-2008 at 01:39 PM. |
Thread Tools | |
Display Modes | |
