Old 06-27-2008, 11:03 AM   #1
Alex1
Alex1's Avatar
front sway bar
My truck did not come with a sway bar and i was wondering if I purchase a performance one, is it a bolt in deal? are all the correct holes drilled from the factory?
Alex1 is offline   Reply With Quote
Old 06-27-2008, 01:00 PM   #2
LONGHAIR
Re: front sway bar
The holes should be there for a "stock" unit. So, if you purchase an aftermarket "hi-performance" piece, it will depened up whether it was designed to fit the original locations or not.
LONGHAIR is offline   Reply With Quote
Old 06-27-2008, 01:44 PM   #3
BowTieOgre
Re: front sway bar
There are "L" shaped frame to sway bar brackets that are riveted to the frame on a truck that came stock with a sway bar and the "U" shaped brackets that go around the bushings are attached to them. You can buy them in the aftermarket for $150 or so plus shipping or justdo what I did. I went to the local junkyard and bought a 1.25" sway bar (with bushing brackets) off of a '76 Camper Special for $15 and spent another $36 on new Moog bushings. You dont NEED the frame to sway bar brackets as you can bolt the "U" shaped ones directly to the frame. In the case of a lowered truck you can score a little more ground clearance doing it that way.
* You will have to drill holes for the bolts if you decide to nix the riveted brackets.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 06-28-2008, 12:05 PM   #4
S10Fan
Old Heap Driver
Re: front sway bar
After a frustrating trip to the junkyard yesterday, your post was the very information I was looking for. Thank You.
Of course, if you had posted this information Thursday I could have saved 20 bucks in gas.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-28-2008, 02:28 PM   #5
justcuz
justcuz's Avatar
Re: front sway bar
The L shaped bracket keeps the mounting surface for the bar flat so the bushing does not bind. In BTO's picture it looks like his bar goes through the a arm bushing enough to move it forward a little, maybe enough so it is bolted to the flat section of the frame. My 72 does not have a factory sway bar either, but I am going the other way with one ton front springs and probably will not use one at all. I live in So Cal and do a lot of off roading, all my stuff is capable of going down a dirt road.
justcuz is offline   Reply With Quote
Thread Tools
Display Modes
