Old 07-03-2008, 02:33 AM   #1
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
Thumbs down Leafs to Trailing Arms?
What would be involved in this "conversion"? I am looking in to buying a 1970 C20 LWB with leafsprings, but I would prefer trailing arms. What is needed for this? Also is there a difference between the trailing arm lengths of a SWB vs. a LWB truck? Is the crossmember just placed differently?
Thanks in advance,
Jared
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 07-03-2008, 03:05 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Leafs to Trailing Arms?
i can't speak to the swap, but there is no difference between lwb and swb t arms or the x member.
i would assume that all you'd need to do for the swap is mount the x member and t-arms, then add the perch to the axle for the t-arms to mount. oh, and you'll need a panhard bar too. assuming you rear end doesn't have the bolt for it, you could go with an after market adjustable on that mounts to the passenger side t-arm mount.
shock mounts will also need to be changed over as they mount to a plate on the bottom of the t arm
IvelDesigns is offline   Reply With Quote
Old 07-03-2008, 10:07 AM   #3
Ackattack
Ackattack's Avatar
It shouldn't be too hard, especially if you do a lowering kit that includes some of the stuff.
ECE sells some kits that include a longer panhard bar and mount (that doesn't mount to the axle), shock brackets, u-bolts, etc.
The toughest part I could see is getting the trailing arm perches welded to the axle, and that's not too hard anyways.
Ackattack is offline   Reply With Quote
Old 07-03-2008, 10:13 AM   #4
Frizzle Fry
Frizzle Fry's Avatar
LWB leaf trucks with two piece drive shafts actually have the trailing arm crossmembers in place for the carrier bearing (not sure about SWB/Leafs). So you would need the arm, hangers, and axle pads as a start. Then panbhard bar, shock mounts, shock xmember, and figure out mounting the springs to the frame. Check out what Gringoloco did on his blazer. He also did the conversion on a truck if you can find the thread.
Frizzle Fry is offline   Reply With Quote
Old 07-03-2008, 10:30 AM   #5
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=294227
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-04-2008, 03:33 AM   #6
SRH916
SRH916's Avatar
So one last question since this seems simple enough. I don't think that if I buy this truck I will be cutting the frame any time soon, so would the trailiing arm xmember on the LWB 3/4 ton be in the right place to just add the arms and have the differential in the right position? (kinda understand me?)
Thanks for the help,
Jared
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 07-04-2008, 04:11 AM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I dont think that the position of the cross member changes any from a leaf to a coil spring truck... So I believe that it would be in the correct place to just add the trailing arms
Sinister
Killer
Old 07-07-2008, 08:56 PM   #8
SRH916
SRH916's Avatar
How hard would it be to just lose the springs and shocks and just go with coilovers on the trailing arms? I haven't been able to find a write up on this, and I know there are a few people with them on their trucks (mostly for drag racing) I would like to know a bit more about these setups though.
- Stock
- "BIG 10"
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
Old 07-08-2008, 06:50 AM   #9
S10Fan
Old Heap Driver
I'm sure it could be done with some basic fabrication skills. One of the shock/coilover companies could point you in the right direction for spring/shock selection. The right coilovers will allow you to set the desired ride height be it normal, low, or raised.
I built trailing arms for my S-10 and used coilovers. My project would be of little help to you, different style arms, different size trucks. I love what I ended up with, good ride and I can adjust the height if need be.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Thread Tools
Display Modes
