07-07-2008, 02:26 PM | #1 |
Aftermarket Bmpr Brkt Problems
I bought some aftermarket bumper brackets off ebay for my short fleet and when i put my new bumper up there it sits just about tight against the back of the box just below the taillights and the bumper sits so high i cannot fully lower my tailgate. Has anybody else had this problem? I thought about modifying the brackets but didnt wanna cut a new pair up. How much of a gap should i have between the bedsides and bumper? Is there somebody that makes a good set of reproductions or somebody that has a set of OEM's they would sell me? Thanks for the help in advance!
07-07-2008, 03:01 PM | #2 |
Nothing to see here.....
Re: Aftermarket Bmpr Brkt Problems
post up a pic of how they are mounted. I've heard of a lot of bumper bracket issues, but this one is the first. stepside or fleet, swb or fleet, 4x or 2x?
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
07-07-2008, 03:06 PM | #3 |
I wont have pics until the weekend but its a 71 short fleet with the chrome sport factory bumper. The outer and inner bracket on each side share a bolt and the inner has another bolt farther ahead to itself if that helps any. They look alot like the outer brackets for the front bumper in that they are just C-channel.
07-07-2008, 03:44 PM | #4 |
Not a chance they ARE front brackets is there?
On my rear brackets, it seemed weird they were angled down kind of.... are the bends in the one bracket (on each side) setting properly "around" the bolt in the crossmember? If you see it, it will make sense what I'm referring to... (Boy, that all seemed like bs type help didn't it...)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
07-07-2008, 03:55 PM | #5 |
I wish I was a cowboy
I got some brackets from LMC, they fit perfectly without any issues, adjustments - I have the same bumper, sits about 1/2 inch away from box.
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
07-07-2008, 04:15 PM | #6 |
LMC's brackets for a stepside sport bumper are NOT made correctly. The bumper is located up & down and front to rear correctly as far as spacing is concerned, but the the bumper is not hung correctly as far as the angle. That sounds goofy, but think of looking at a bumper from the side and the section that wraps around the rear of the truck. As opposed to running "flat", then ends turn down.
Gonna take some persuasion from a very large hammer and the Blue Flame wrench to correct. Last edited by Shane; 07-07-2008 at 04:36 PM. |
07-07-2008, 04:29 PM | #7 |
What about Jim Carters or Brother's brackets? I'm about to buy brackets and a bumper and don't want any problems.
07-07-2008, 04:52 PM | #8 | |
Retired Air Force Veteran
I bought mine from Tim (Uncle). There's also: Randy (teeitup) Bill (billsbowtie) Wes (Classic Heartbeat) I would suggest subscribing to the board. You'll find lots of parts for sale and you'll be able to sell extra parts. (the best $25.00 a year you will spend if you plan on keeping your truck) Good Luck.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
07-07-2008, 05:54 PM | #9 | |
I solved the issue with a bevel washer. bevel washers are used to create a flat surface for an anchor bolt to mount to on the web of a "c" channel. ask a heavy building supply house for "channel washers" or bevel washers. worked like a charm and the bumper is perfectly flat
07-07-2008, 06:34 PM | #10 | |
07-07-2008, 08:46 PM | #11 |
The Older Generation
I used a rear after market sport bumper and brackets with no issues. Sumpthin' funny goin' on there.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-07-2008 at 08:46 PM. |
Thread Tools | |
Display Modes | |
