07-09-2008, 04:06 PM | #1 |
drum brake 5 lug?
did they ever make a truck with drums and 5 lug wheels? I was told some guy here in my town had one, but I thought anything w/ 5 lug was a disc brake setup?
07-09-2008, 09:11 PM | #2 |
its all about the +6 inches
Re: drum brake 5 lug?
the smart @ss answer is yes....
all the 1/2 ton trucks in 71/72 had 5 lug drums... in back. But the real answer is no. There were no 5 lug 4 wheel drum trucks made from GM.... maybe back in the turn of the century times... but nothing that we talk about in here. |
07-10-2008, 09:32 AM | #3 |
yea i guess i could of been more clear, i knew there were rear drums, hell even some of the new 08 chevy trucks at work have rear drums
07-10-2008, 09:47 AM | #4 |
Active Member
Unless the previous owner/owners had the axles redrilled for 5 lugs drums all around, there weren't made that way.
Some years back you were limited on the after market wheels so some guys redrilled the axles to accept 5 lug wheels. Last edited by 68gmsee; 07-10-2008 at 09:49 AM. Reason: lost part of sentence |
07-10-2008, 10:12 AM | #5 |
i can see re drilling the rear axles, but re drilling the front spindles? you'd have to drill new holes in your brake drums also, or do they make a 5 lug setup after market? i know they made a 6 lug disc setup after market.
07-10-2008, 11:09 AM | #6 |
never heard of nor seen aftermarket 5 lug drums.
I wonder if this guy used car components. |
07-10-2008, 11:26 AM | #7 | |
o well, it doesn't matter anyway, i just though i was right and wanted to check |
07-10-2008, 12:25 PM | #8 |
older impalas have 5 lug drums as well as most other 50`s and early 60`s cars. I bet he used a front end off an old biscayne or something
1967custom |
07-10-2008, 02:19 PM | #9 |
and the bigger cars had the 5 on 5 bolt pattern. But the thing I wonder is if the car hub (even big pattern hubs) would go on a truck spindle.
Either way, it isn't original by any means |
Thread Tools | |
Display Modes | |
