Old 11-11-2002, 06:28 PM   #1
TC70C10
TC70C10's Avatar
Max Tire Size 81 K5 Blazer
Anyone know what is the max size I can run on my stock rim, no lift kit, without rubbing? I'm thinking about running 31x10.5x15 mud tires for 4 wheeling this winter. Someone suggested I go with something larger. Any suggestions/experience appreciated.
TC
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 11-11-2002, 06:29 PM   #2
TC70C10
TC70C10's Avatar
BTW rim is 15x8
Harvest, AL 35749
Old 11-11-2002, 07:19 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I have a stock height 84 K10 Pickup and run 32x11.50 BFG Radial A/Ts.
This is my second set and when they are new, the rub just slightly when turning and backing up (ie pulling out of a parking spot) They don't rub no matter what if you are going forward. After about 10000 miles, they don't rub no matter what.
I wouldn't run any larger without some sort of lift.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 11-11-2002, 07:41 PM   #4
85 K5
Some have gone to 35's without lift. Fender trimming is required. Get out your sawzall and go to it. It can be done so it's not noticable for 32's, find a ditch or something and mark the part that needs to go when flexing, wheels turned.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 11-13-2002, 11:03 AM   #5
TC70C10
TC70C10's Avatar
I have the heavy duty suspension (dual front shocks). Someone suggest I have 33's mounted and see how they fit. I'm just not sure if they'll fit on 15x8's
Harvest, AL 35749
Old 11-13-2002, 11:22 AM   #6
Prerunner1982
Prerunner1982's Avatar
tire size
i run 31x11.50s on my 82 c10... so i am sure you could fit something bigger than that on your 4by...
jon
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 11-21-2002, 01:22 AM   #7
monypit
monypit's Avatar
ou can go up to a 12.5 in wide tire on the 15 x 8 stock rim. The height isn't as critical according to Discount Tire. I put 35x12.50/15 on my stockers
1973/1997 Blazer/Tahoe (it just doesn't know that it is a '73)
monypit is offline   Reply With Quote
Old 11-21-2002, 04:02 AM   #8
79Silv4x4
Workaholic
79Silv4x4's Avatar
I'd go with the 33s. On stock rims you'll have no clearance problem unless you get into some serious wheeling.
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Thread Tools
Display Modes
