Old 11-11-2002, 09:54 PM   #1
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
SM420 and NP205
Did they make this combo? The sm420 is one of the strongest trannies that i have known and many people agree, what about you? I have a 2wd version that I want to convert to a 4wd married to the t/c. Is this hard? I know finding one is nearly impossible. Has anyone did this swap and do you think that it would put up with 650-750 ft-lbs torque? What would be the strongest drivetrain to put up with that kinda power. Thanks
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 11-11-2002, 10:08 PM   #2
GMC71k20
what do you have that will put out 650-750 ft/lbs of torque?
GMC71k20 is offline   Reply With Quote
Old 11-11-2002, 10:56 PM   #3
stelth2002
stelth2002's Avatar
A tuned up cummins 6bt. Im thinking about using a GM tranny/tc. It would be smaller and cheaper to use by several 1K. Thanks
Old 11-12-2002, 12:11 AM   #4
Rod
Seen the sm240 / np205 married combo in a couple 69's. That would be the year of truck I would check for that combo....
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-12-2002, 12:12 AM   #5
stelth2002
stelth2002's Avatar
The Sm420 was only produced from 1948-1967 i believe. They were put in the bigger 2.5 ton trucks all the way to 1/2 tons. Was it a stock combo you think or modified? I need all the info I can get.
Old 11-12-2002, 08:43 AM   #6
Blazer1970
Blazer1970's Avatar
If there ever was a 420/205 married combo, it was very rare. I have never seen or heard of it. SM465/NP205 on the other hand, is just as strong and there are tons of them out there. That is what I would use.
Blazer1970 is offline   Reply With Quote
Old 11-12-2002, 11:30 PM   #7
stelth2002
stelth2002's Avatar
Anybody else have any advice for me? The reason I want to go with the sm420 is that it is just as strong, but it is 2 inches shorter and 50 pounds lighter. You may not think its much, but if I can it would help my driveline angles and the engine is going to weigh 400 pounds more than the stock one, so I would like to sheer some pounds were I can. In the pre67 how is the 4 wheel drive setup?? Anyone know?? Thanks
Thread Tools
Display Modes
