07-14-2008, 04:00 PM | #1 |
283 Drama Queen
T350 Floor Shifter for a 65' C10?
The guy that ripped my truck off tore up the steering column and it’s going to be too much of a hassle trying to get the original linkage working. I was wondering if anyone’s got any experience in installing a floor shifter for a three-speed-automatic?
This is the one I’m considering: Part Number: HUU-3838520 / Hurst V-Matic 2 Shifter Hurst 3838520: $215.95 Any knowledge will be greatly appreciated.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
07-14-2008, 04:16 PM | #2 |
TexasBowhunter
Re: T350 Floor Shifter for a 65' C10?
This one is built for trucks and should be a little higher profile.
Amazon.com: B&M 80680 Truck/SUV MegaShifter...
Build in progress for son's first truck. |
07-14-2008, 04:25 PM | #3 |
283 Drama Queen
Outstanding - does it care if it goes on a 65'?
07-14-2008, 04:27 PM | #4 |
TexasBowhunter
My understanding is that you trim the bottom to fit the contour of your floor board.
I may have to go this route soon.
07-14-2008, 04:41 PM | #5 |
The kid that had my last truck b4 me cut a hole and put in a make shift set up. I had to place a patch in the floor and recut for a Genie floor shift kit featuring Swan shifter & REAL 8 Ball handle.. Worked out just fine. Here are a couple of pics.
Good Luck! Norm
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
07-14-2008, 05:11 PM | #6 |
283 Drama Queen
I'll be darned - had nearly the identicle set-up in my 66' GMC pick-up! It was already in the truck when I got her and never had a lick of trouble for three years. Do they still sell that assembly?
07-14-2008, 05:27 PM | #7 | |
Order on line: http://www.bowtieoverdrives.com/cata...hp?ITEMID=529_
07-14-2008, 05:48 PM | #8 |
283 Drama Queen
Item: 23" Gennie Ultra Swan TH-350 (1002G2)
Price: $249.95 / Part #: S1002G2 Got to admit - that’s a nice looking shifter. The shorter one’s okay too - but I’m concerned about clearing the bench seat. The price isn’t too bad either. Good catch, 64c20crewcab!
07-14-2008, 05:55 PM | #9 | |
I had a slight issue with the bench seat. I had planned to have my seat redone with a notch cut out of the center front of the seat pad just so i'd have the proper clearance. Hoverver you can als use the 28" Genie lever too.
07-14-2008, 06:01 PM | #10 |
283 Drama Queen
Yeah - I think I'll go for the long one - just cause it looks trick, then I won't have to worry about clearance. The one in the Jimmy came right back against the seat when in 'low', but never created a problem.
07-14-2008, 06:08 PM | #11 | |
Thanks Man! Norm
07-14-2008, 06:38 PM | #12 |
283 Drama Queen
Will do!
Mac
07-16-2008, 03:28 PM | #13 |
Does anyone have pics of the linkages.
07-16-2008, 08:54 PM | #14 |
Sorry I don't. but the kit includes the handle of your choice with standard knob, mount bracket that attaches to 4 spots (i think?) on the tranny - using existing threaded locations, the shift arm and linkage rod(s). Note that this is all from memory so I may not be exact. I installed it on my last truck on Superbowl Sunday in 2000. One thing I do recall for sure is that the install is very easy & not complicated at all. I tried hunting down the company site but could not find it. I had the link to that site on my last computer but that machine got stolen. I'd did see that Lokar now makes a swan style shifter that is 32" long - now that will look SLICK!
Good Luck!
07-17-2008, 12:16 AM | #15 |
My tranny doesn't have any linkages. (i didn't pull it) so I have nothing to referance.
07-17-2008, 12:23 PM | #16 |
283 Drama Queen
Okay Guys, I told you the truck I’m working on got stolen back in February, right? Well, the transmission that came with the V-8 (283) that I’m shipping off for rebuild Saturday, is one of those nasty old Saginaw clunkers. I finally got if off the engine last night - with the bell housing, and the starter was attached to the latter.
Question: Should that same starter somehow bolt up to the 283 without a big science project to make it happen? (BTW: Which one of you is coming to my house this weekend to pick up this 3-speed?)
07-17-2008, 12:46 PM | #17 | |
Were you refering to stock or the Genie shift linkage? It's one rod connected to shift arm on tranny. really simple. I can get & post pic of my stock th350 setup if needed.
07-17-2008, 05:45 PM | #18 | |
At this point any picture would help. I haven't picked a shifter yet, but $ is going to be the determining factor. I was thinking of using a cheepy Mr. Gasket one. |
07-18-2008, 12:41 AM | #19 | |
60-66 Nut
07-18-2008, 10:35 AM | #20 |
283 Drama Queen
OUTSTANDING!
That’s exactly what I needed to know - and is a zero problem issue, as I have to buy a new flexplate anyway. This gives me something to work with - as I have no experience (obviously) in this kind of conversion. Thanks. Mac
Thread Tools | |
Display Modes | |
