Old 07-18-2008, 05:31 AM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
Coolant leak
Hey guys.. I've got radiator coolant leaking but I can't figure out where it's coming from. It's dripping off one of the bolts from the transmission pan. the front corner bolt on the drivers side. It shouldn't be coming out of the radiator pan. And the tranny cooling lines are on the passenger side. Where could it be coming from??
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 07-18-2008, 07:45 AM   #2
stingray72
stingray72's Avatar
Re: Coolant leak
I took a picture incase it helps
click it for the big easy to see one
-Homer Simpson
Old 07-18-2008, 07:51 AM   #3
jj_adams319
jj_adams319's Avatar
Re: Coolant leak
freeze plug?
jj_adams319 is offline   Reply With Quote
Old 07-18-2008, 08:45 AM   #4
steelhorse
steelhorse's Avatar
Re: Coolant leak
Get or borrow a pressure tester it will help you find it.It could be a freeze plug or maybe the back of the intake.
steelhorse is offline   Reply With Quote
Old 07-18-2008, 08:51 AM   #5
stingray72
stingray72's Avatar
Re: Coolant leak
Called a mechanic buddy and he said the exact same thing. Funny how that works. he's bringing the pressure tester over early next week and we're going to diagnose
Intake will be done in the d/w. Freeze plugs at the shop. I;m not dropping the tranny in the d/w. Been there done that. not again
-Homer Simpson
Old 07-18-2008, 12:48 PM   #6
steelhorse
steelhorse's Avatar
Re: Coolant leak
I am a mechanic too,so we must think alike
Old 07-18-2008, 08:33 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Coolant leak
if it is a freeze plug, it'll be a lower one, probably on the backside of the oil filter.
No need to drop the tranny.
If this is the case, I highly recomend popping ALL the lower freeze plugs out and flushing all the rust out of it. There will be a lot there if your plug rusted out. Then replace them all with new bras ones.
Thread Tools
Display Modes
