Old 07-18-2008, 08:02 AM   #1
steelhorse
steelhorse's Avatar
Sway bar
I am planning on using 73-87 front suspension on my 67 does anyone know if the sway bar will work or what mods need to be done?
steelhorse is offline   Reply With Quote
Old 07-18-2008, 10:01 AM   #2
JimKshortstep4x4
Re: Sway bar
4x4 or 2wd?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-18-2008, 10:17 AM   #3
steelhorse
steelhorse's Avatar
Re: Sway bar
2wd
Old 07-18-2008, 12:24 PM   #4
ERASER5
ERASER5's Avatar
Re: Sway bar
Mods-- One rivet will have to be cut out of your 67 to mount the stand off brackets. That's it. You will see which one as soon as you hold the brackets in place. All other holes are already there. Oh yea, I would recommend grade 8 bolts, washers, and nuts.
Is your truck going to be lowered? If so, you will need a "lowered" stand off bracket from ECC or similar vender.
I am in the middle of the same swap you are doing. No lowering for me, at least not yet.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-18-2008, 12:32 PM   #5
steelhorse
steelhorse's Avatar
Re: Sway bar
I am plannig on going with drop spindles and 1 inch springs in ft and four inch in the back
Old 07-18-2008, 04:55 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Sway bar
This is it here:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Get the big bar (1 1/4") off of a towtruck or something similar...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Thread Tools
Display Modes
